    Current Weather Module Issue
    3 Posts 2 Posters 2.2k Views 2 Watching
    • E Offline
      ericker
      Hi All,
      I’m having an issue with the current weather module. It appears the time is not updating, but the weather is. For instance, yesterday I monitored it for a few hours and the weather changed but the time stayed at 7:17 AM. I checked again this morning and it changed to 4:24 PM. The forecast module looks to be correct and my time is correct everywhere else including the clock module and raspberry pi system.
      I’ve looked at the documentation for this module. I’ve kept the updateInterval at 10 minutes. I tried changing to a 24 time format but that didn’t make any difference. Even when I restart the magic mirror program or reboot the pi, it will stay at the same time like 7:17 AM. I also moved it closer to my router in case of a connection problem. Maybe I’m getting this wrong and it’s not supposed to change?
      Has anyone else experienced this or have an idea of what could be going on?
      Thanks.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @ericker
        @ericker isn’t the time of the weathermodule the sunrise and sunset time?
        • E Offline
          ericker
          That would make a lot of sense. I was expecting that the time would update every time the weather updated. I’m going to re-check the documentation for the module.
