    MMM-network-signal - make the message text larger
    18 Posts 3 Posters 6.1k Views 3 Watching
      DarrenHill @DarrenHill
      @sdetweil I’ve dug a bit deeper and can see that the custom.css is there, but seems to be being overwritten (it’s crossed out)?
      Here’s a screenshot of the mirror (apologies for quality, it’s via phone). Can you guide where I should be looking or clicking for this?
      Mirror screenshot
        Better picture, having set up client/server:
        Desktop screengrab
          @sdetweil So looks like the element is p as you correctly surmised before, but for some reason the custom.css entry is getting overwritten or somehow blocked (you can see it’s there in the inspector, but struck through)?
          Here now I have no idea, aside from breaking rule 1 and just editing the js file directly…
          The config.js setting for the module is:
                      module: "MMM-network-signal",
                      position: "bottom_right",
                          server: "8.8.8.8",
                          showMessage: true,
                          flexDirection: "row-reverse",
                          scale: 0.35
          And the custom.css entry is :
          .MMM-network-signal p {
            font-size: 1.5em;
          I also tried fontSize: as per your original suggestion, but that didn’t work either.
            sdetweil @DarrenHill
            @DarrenHill said in MMM-network-signal - make the message text larger
                font-size: 1.5em;
            yeh, override is tricky sometimes… the ‘nearest’ specified (to the targeted thing) style wins…
            in this case the style= specified ON the element itself
            UNLESS
            you add !important
            this works
                font-size: 1.5em !important;
            https://www.w3schools.com/css/css_important.asp
              DarrenHill @sdetweil
              @sdetweil And we have a winner :D
              That one worked as you say, thanks Sam!
              So yesterday’s learning was GitHub, today’s is CSS ;)
              mumblebajM S 2 Replies Last reply Reply Quote 0
              • mumblebajM Offline
                mumblebaj Module Developer @DarrenHill
                @DarrenHill this worked for me. note the , before the p
                .MMM-network-signal ,p {
                font-size: 1.5em;
                color: yellow;
                  sdetweil @mumblebaj
                  @mumblebaj where do you see the leading comma in the css selector definition, except for allowing the same style to apply to multiple selectors
                  .class element1, element2, element3 {
                     styles
                  vs having three separate definitions…
                  .class element1{
                     styles
                  .class element2 {
                     styles
                  .class element3 {
                     styles
                    @DarrenHill said in MMM-network-signal - make the message text larger:
                    also see the ways you can select elements
                    https://www.w3schools.com/cssref/css_selectors.asp
                      @sdetweil Try it. It works. I tested it.
                      D S 2 Replies Last reply Reply Quote 0
                        DarrenHill @mumblebaj
                        @mumblebaj Just tried it (copy/paste from your code above) and whilst the yellow works, the font-size didn’t for me.
                          sdetweil @mumblebaj
                          @mumblebaj well, it made the font bigger, but NOT 1.5em…
