    MMM-network-signal - make the message text larger
    18 Posts 3 Posters 6.2k Views 3 Watching
      sdetweil @DarrenHill
      @DarrenHill what IS the element?
      should be a paragraph
      u can change it in the top right box, then swipe/select the new settings, and copy/paste to custom.css
      the custom.css is
      . (for class)modulename (exact text case) element {
      styles
      and I should be able to see where the styles come from
        DarrenHill @sdetweil
        @sdetweil I’m not sure I’m doing this right.
        I’ve pressed ctrl+shift+i and got the inspector window up, then selected the elements tab (although it’s the default selection anyway) then clicked on the mouse pointer icon at top-left and then clicked onto the message text in the main mirror window.
        When I do that I get the sub-window at the bottom of the inspector with div and P tabs, with the P tab selected. There I can see element.style with the text-align and font-size sub-entities plus user agent and main.css items.
        P I take it from the code is the paragraph entity I need to be resizing, and from the top of the code the module name is .MMM-network-signal but it’s the rest of the top line to go into custom.css that I’m struggling to identify.
        I’m not sure what you’re referring to by top-right box? I can see an icon for a computed styles sidebar, but there’s nothing much in there that isn’t in the other window area? This is on a Pi3 in a PiTop Ceed, so whilst I have keyboard/mouse connected up, my screen size is not so large to display everything without restricted menus (so I might be missing something here)
          DarrenHill @DarrenHill
          @sdetweil I’ve dug a bit deeper and can see that the custom.css is there, but seems to be being overwritten (it’s crossed out)?
          Here’s a screenshot of the mirror (apologies for quality, it’s via phone). Can you guide where I should be looking or clicking for this?
          Mirror screenshot
            Better picture, having set up client/server:
            Desktop screengrab
              @sdetweil So looks like the element is p as you correctly surmised before, but for some reason the custom.css entry is getting overwritten or somehow blocked (you can see it’s there in the inspector, but struck through)?
              Here now I have no idea, aside from breaking rule 1 and just editing the js file directly…
              The config.js setting for the module is:
                          module: "MMM-network-signal",
                          position: "bottom_right",
                              server: "8.8.8.8",
                              showMessage: true,
                              flexDirection: "row-reverse",
                              scale: 0.35
              And the custom.css entry is :
              .MMM-network-signal p {
                font-size: 1.5em;
              I also tried fontSize: as per your original suggestion, but that didn’t work either.
                @DarrenHill said in MMM-network-signal - make the message text larger
                    font-size: 1.5em;
                yeh, override is tricky sometimes… the ‘nearest’ specified (to the targeted thing) style wins…
                in this case the style= specified ON the element itself
                UNLESS
                you add !important
                this works
                    font-size: 1.5em !important;
                https://www.w3schools.com/css/css_important.asp
                  @sdetweil And we have a winner :D
                  That one worked as you say, thanks Sam!
                  So yesterday’s learning was GitHub, today’s is CSS ;)
                  mumblebajM S 2 Replies Last reply Reply Quote 0
                  • mumblebajM Offline
                    mumblebaj Module Developer @DarrenHill
                    @DarrenHill this worked for me. note the , before the p
                    .MMM-network-signal ,p {
                    font-size: 1.5em;
                    color: yellow;
                      sdetweil @mumblebaj
                      @mumblebaj where do you see the leading comma in the css selector definition, except for allowing the same style to apply to multiple selectors
                      .class element1, element2, element3 {
                         styles
                      vs having three separate definitions…
                      .class element1{
                         styles
                      .class element2 {
                         styles
                      .class element3 {
                         styles
                        @DarrenHill said in MMM-network-signal - make the message text larger:
                        also see the ways you can select elements
                        https://www.w3schools.com/cssref/css_selectors.asp
                          @sdetweil Try it. It works. I tested it.
                          D S 2 Replies Last reply Reply Quote 0
                            DarrenHill @mumblebaj
                            @mumblebaj Just tried it (copy/paste from your code above) and whilst the yellow works, the font-size didn’t for me.
                              sdetweil @mumblebaj
                              @mumblebaj well, it made the font bigger, but NOT 1.5em…
