    MMM-network-signal - make the message text larger
    18 Posts 3 Posters 6.4k Views 3 Watching
      sdetweil @DarrenHill
      @DarrenHill because it’s the only paragraph (“p”) tag, u can target that.
      .MMM-network-signal p {
          fontSize: 1.5em;
      D 1 Reply Last reply
        DarrenHill @sdetweil
        @sdetweil said in MMM-network-signal - make the message text larger:
        fontSize: 1.5em;
        Thanks for the suggestion Sam. Unfortunately when I added that to custom.css and restarted, I’ve still got microscopic text :(
        I also tried font-size: instead of fontSize: (like other css items I have in there, and like in the js file) but that doesn’t work either.
          @DarrenHill I am on my phone, look at this
          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1648929944792
            @sdetweil I can see the two entries (text-align and font-size) in there under element.style when I select the message text.
            I’m not sure how this helps us though? Is that what I should be looking to find, the element.style tag?
              @DarrenHill what IS the element?
              should be a paragraph
              u can change it in the top right box, then swipe/select the new settings, and copy/paste to custom.css
              the custom.css is
              . (for class)modulename (exact text case) element {
              styles
              and I should be able to see where the styles come from
                @sdetweil I’m not sure I’m doing this right.
                I’ve pressed ctrl+shift+i and got the inspector window up, then selected the elements tab (although it’s the default selection anyway) then clicked on the mouse pointer icon at top-left and then clicked onto the message text in the main mirror window.
                When I do that I get the sub-window at the bottom of the inspector with div and P tabs, with the P tab selected. There I can see element.style with the text-align and font-size sub-entities plus user agent and main.css items.
                P I take it from the code is the paragraph entity I need to be resizing, and from the top of the code the module name is .MMM-network-signal but it’s the rest of the top line to go into custom.css that I’m struggling to identify.
                I’m not sure what you’re referring to by top-right box? I can see an icon for a computed styles sidebar, but there’s nothing much in there that isn’t in the other window area? This is on a Pi3 in a PiTop Ceed, so whilst I have keyboard/mouse connected up, my screen size is not so large to display everything without restricted menus (so I might be missing something here)
                  DarrenHill @DarrenHill
                  @sdetweil I’ve dug a bit deeper and can see that the custom.css is there, but seems to be being overwritten (it’s crossed out)?
                  Here’s a screenshot of the mirror (apologies for quality, it’s via phone). Can you guide where I should be looking or clicking for this?
                  Mirror screenshot
                    Better picture, having set up client/server:
                    Desktop screengrab
                      @sdetweil So looks like the element is p as you correctly surmised before, but for some reason the custom.css entry is getting overwritten or somehow blocked (you can see it’s there in the inspector, but struck through)?
                      Here now I have no idea, aside from breaking rule 1 and just editing the js file directly…
                      The config.js setting for the module is:
                                  module: "MMM-network-signal",
                                  position: "bottom_right",
                                      server: "8.8.8.8",
                                      showMessage: true,
                                      flexDirection: "row-reverse",
                                      scale: 0.35
                      And the custom.css entry is :
                        font-size: 1.5em;
                      I also tried fontSize: as per your original suggestion, but that didn’t work either.
                        @DarrenHill said in MMM-network-signal - make the message text larger
                            font-size: 1.5em;
                        yeh, override is tricky sometimes… the ‘nearest’ specified (to the targeted thing) style wins…
                        in this case the style= specified ON the element itself
                        UNLESS
                        you add !important
                        this works
                            font-size: 1.5em !important;
                        https://www.w3schools.com/css/css_important.asp
                          @sdetweil And we have a winner :D
                          That one worked as you say, thanks Sam!
                          So yesterday’s learning was GitHub, today’s is CSS ;)
                          mumblebajM S 2 Replies Last reply
                          • mumblebajM
                            mumblebaj Module Developer @DarrenHill
                            @DarrenHill this worked for me. note the , before the p
                            .MMM-network-signal ,p {
                            font-size: 1.5em;
                            color: yellow;
                              sdetweil @mumblebaj
                              @mumblebaj where do you see the leading comma in the css selector definition, except for allowing the same style to apply to multiple selectors
                              .class element1, element2, element3 {
                                 styles
                              vs having three separate definitions…
                              .class element1{
                                 styles
                              .class element2 {
                                 styles
                              .class element3 {
                                 styles
                              mumblebajM 1 Reply Last reply
                                @DarrenHill said in MMM-network-signal - make the message text larger:
                                also see the ways you can select elements
                                https://www.w3schools.com/cssref/css_selectors.asp
                                • mumblebajM
                                  @sdetweil Try it. It works. I tested it.
                                  D S 2 Replies Last reply
                                    DarrenHill @mumblebaj
                                    @mumblebaj Just tried it (copy/paste from your code above) and whilst the yellow works, the font-size didn’t for me.
                                      sdetweil @mumblebaj
                                      @mumblebaj well, it made the font bigger, but NOT 1.5em…
