    MMM-network-signal - make the message text larger
    18 Posts 3 Posters 6.3k Views 3 Watching
      DarrenHill
      I’m trying to adjust MMM-network-signal to make the message text larger. At the moment it’s at 0.65em, which on my mirror is microscopic.
      I can see that it’s set in line 58 of the js file (see here ), and if I do a test with manual editing it works fine.
      But I’d like to override it with a custom.css entry instead, but I’m struggling to work out what the syntax would be for that specific item.
      Can someone give me some pointers as to what the entry in custom.css would need to be to override the 0.65em to 1.5em?
        sdetweil @DarrenHill
        @DarrenHill because it’s the only paragraph (“p”) tag, u can target that.
        .MMM-network-signal p {
            fontSize: 1.5em;
          DarrenHill @sdetweil
          @sdetweil said in MMM-network-signal - make the message text larger:
          fontSize: 1.5em;
          Thanks for the suggestion Sam. Unfortunately when I added that to custom.css and restarted, I’ve still got microscopic text :(
          I also tried font-size: instead of fontSize: (like other css items I have in there, and like in the js file) but that doesn’t work either.
            @DarrenHill I am on my phone, look at this
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1648929944792
              @sdetweil I can see the two entries (text-align and font-size) in there under element.style when I select the message text.
              I’m not sure how this helps us though? Is that what I should be looking to find, the element.style tag?
                @DarrenHill what IS the element?
                should be a paragraph
                u can change it in the top right box, then swipe/select the new settings, and copy/paste to custom.css
                the custom.css is
                . (for class)modulename (exact text case) element {
                styles
                and I should be able to see where the styles come from
                  @sdetweil I’m not sure I’m doing this right.
                  I’ve pressed ctrl+shift+i and got the inspector window up, then selected the elements tab (although it’s the default selection anyway) then clicked on the mouse pointer icon at top-left and then clicked onto the message text in the main mirror window.
                  When I do that I get the sub-window at the bottom of the inspector with div and P tabs, with the P tab selected. There I can see element.style with the text-align and font-size sub-entities plus user agent and main.css items.
                  P I take it from the code is the paragraph entity I need to be resizing, and from the top of the code the module name is .MMM-network-signal but it’s the rest of the top line to go into custom.css that I’m struggling to identify.
                  I’m not sure what you’re referring to by top-right box? I can see an icon for a computed styles sidebar, but there’s nothing much in there that isn’t in the other window area? This is on a Pi3 in a PiTop Ceed, so whilst I have keyboard/mouse connected up, my screen size is not so large to display everything without restricted menus (so I might be missing something here)
                    DarrenHill @DarrenHill
                    @sdetweil I’ve dug a bit deeper and can see that the custom.css is there, but seems to be being overwritten (it’s crossed out)?
                    Here’s a screenshot of the mirror (apologies for quality, it’s via phone). Can you guide where I should be looking or clicking for this?
                    Mirror screenshot
                      Better picture, having set up client/server:
                      Desktop screengrab
                        @sdetweil So looks like the element is p as you correctly surmised before, but for some reason the custom.css entry is getting overwritten or somehow blocked (you can see it’s there in the inspector, but struck through)?
                        Here now I have no idea, aside from breaking rule 1 and just editing the js file directly…
                        The config.js setting for the module is:
                                    module: "MMM-network-signal",
                                    position: "bottom_right",
                                        server: "8.8.8.8",
                                        showMessage: true,
                                        flexDirection: "row-reverse",
                                        scale: 0.35
                        And the custom.css entry is :
                          font-size: 1.5em;
                        I also tried fontSize: as per your original suggestion, but that didn’t work either.
                          @DarrenHill said in MMM-network-signal - make the message text larger
                              font-size: 1.5em;
                          yeh, override is tricky sometimes… the ‘nearest’ specified (to the targeted thing) style wins…
                          in this case the style= specified ON the element itself
                          UNLESS
                          you add !important
                          this works
                              font-size: 1.5em !important;
                          https://www.w3schools.com/css/css_important.asp
                            @sdetweil And we have a winner :D
                            That one worked as you say, thanks Sam!
                            So yesterday’s learning was GitHub, today’s is CSS ;)
                            mumblebajM S 2 Replies Last reply Reply Quote 0
                            • mumblebajM Offline
                              mumblebaj Module Developer @DarrenHill
                              @DarrenHill this worked for me. note the , before the p
                              .MMM-network-signal ,p {
                              font-size: 1.5em;
                              color: yellow;
                                sdetweil @mumblebaj
                                @mumblebaj where do you see the leading comma in the css selector definition, except for allowing the same style to apply to multiple selectors
                                .class element1, element2, element3 {
                                   styles
                                vs having three separate definitions…
                                .class element1{
                                   styles
                                .class element2 {
                                   styles
                                .class element3 {
                                   styles
                                  @DarrenHill said in MMM-network-signal - make the message text larger:
                                  also see the ways you can select elements
                                  https://www.w3schools.com/cssref/css_selectors.asp
                                    @sdetweil Try it. It works. I tested it.
                                    D S 2 Replies Last reply Reply Quote 0
                                      DarrenHill @mumblebaj
                                      @mumblebaj Just tried it (copy/paste from your code above) and whilst the yellow works, the font-size didn’t for me.
                                        sdetweil @mumblebaj
                                        @mumblebaj well, it made the font bigger, but NOT 1.5em…
