    MMM screencast switch automatically to desktop and starts on desktop (ON MAC contd))
    4 Posts 3 Posters 978 Views 3 Watching
      rudiau
      Re: MMM screencast switch automatically to desktop and starts on desktop (ON MAC)
      Having the same problem.
      Screencast appears on the desktop with a second instance of Electron simultaneously appearing on the dock.
      So not appearing in MM.
      Using one display i.e. the laptop.
      Has anyone got this working on a MAC?
      Does it work on a Windows platform or only on the Pi?
      Thanks.
        rudiau
        Reinstalled Node.js, MM and Screencast.
        Pulled from the master.
        Two things I noticed:-
        1. In MMM-Screencast.js it states:
          “requiresVersion: “2.1.0”, // Required version of MagicMirror”
          I’m running v2.19.0) , does this matter?
        2. Terminal Reports
        npm audit report
        <ejs 3.1.7
        Severity: high
        Template injection in ejs - https://github.com/advisories/GHSA-phwq-j96m-2c2q
        No fix available
        node_modules/ejs
        peer-dial *
        Depends on vulnerable versions of ejs
        node_modules/peer-dial
        2 high severity vulnerabilities
        Some issues need review, and may require choosing
        a different dependency.
        Also this report from Terminal on MM boot.
        <[29.04.2022 12:16.12.257] [LOG] screencast stderr: objc[43214]: Class WebSwapCGLLayer is implemented in both /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libANGLE-shared.dylib (0x7ffa58e93318) and /Users/rudi/MagicMirror/modules/MMM-Screencast/node_modules/electron/dist/Electron.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libGLESv2.dylib (0x10b6de9c8). One of the two will be used. Which one is undefined.
        [29.04.2022 12:16.14.074] [LOG] screencast stderr: [43212:0429/121614.073923:ERROR:service_worker_storage.cc(1904)] Failed to delete the database: Database IO error/>
        My bolding.
        One of the two will be used. Which one is undefined.??
        Don’t understand.
        Any help?
        Thanks Rudi.
          rudiau
          Well, that didn’t format as expected.
            sdetweil @rudiau
            @rudiau the audit is useless.
            2.19 is greater than 2.1
