    Trouble playing audio file
    15 Posts 3 Posters 6.1k Views 3 Watching
      sdetweil @mZuil
      @mZuil if u bring up YouTube do you get audio?
      my Ubuntu has lost access to my sound device
      . haven’t figured that out yet
        mZuil @sdetweil
        @sdetweil Yeah, the monitor I use has speakers and I have tried to reproduce YouTube and even this mp3 o wav file without the Magic Mirror started and it works, but when I call some functions to execute the audio with the Magic Mirror it doesn’t work. I am generating this audio with gtts and I don’t know if the problem is because those two actions are executed at the same time:
        const gTTS = require('gtts');
        var play = require('play').Play();
        var gtts = new gTTS('text to speak', 'es-es');
        gtts.save('/tmp/hello.wav', function (err, result) {
          if(err) { throw new Error(err) }
          console.log('Success! Open file /tmp/hello.mp3 to hear result.');
        play.sound('/tmp/hello.wav');
        The code below is one of the many attempts I have tried :(
        Thanks for the response!
          sdetweil @mZuil
          @mZuil can u run this piece of code from a terminal window?
          put the code in xxx.js
          then
          node xxx.js
          does it work?
            mZuil @sdetweil
            @sdetweil Sorry, I couldn’t try it before.
            It doesn’t work :( I am a beginner and I don’t understand well what is happening, could you help me, please? :crying_face:
              sdetweil @mZuil
              @mZuil what does the play() library say about sound output configuration?
              https://github.com/Marak/play.js#readme
              requirements:
              One of the CLI based audio player
              CLI means Command Line Interface
              I think you should have seen this error
                    console.log('No suitable audio player could be found - exiting.'.red);
                sdetweil @mZuil
                @mZuil none of the players listed in his code and doc are installed on raspberry pi os by default.
                bugsounetB 1 Reply Last reply Reply Quote 0
                • bugsounetB Offline
                  bugsounet Banned @sdetweil
                  @sdetweil the problem is not there…
                  The problem is you can’t play a file when it’s not fully created!
                  2 solutions:
                  Make a promise
                  Or play the file when the file is created
                    sdetweil @bugsounet
                    @bugsounet ah yes good catch. I jumped to play()…
                    move the play() inside the callback on save()
                    players will be the next problem
                    bugsounetB 1 Reply Last reply Reply Quote 1
                      just because sometime i'm kind... (my favorite sentence!)
                      Try this:
                      var player = require('play-sound')(
                        opts = {
                          player: "mpg123" // use only `mpg123` for playing sounds
                      // main file player
                      function playing (file) {
                        player.play(file, (err) => {
                          if (err) throw new Error(err)
                      gtts.save('/tmp/hello.wav', (err, result) => {
                        console.log('Success! start playing result.');
                        // right ! sound file is created let's play it !
                        playing("/tmp/hello.wav");
                      Notes:
                      • You need to install mpg123 app with sudo apt-get install mpg123
                      • I replace your play library by play-sound for better compatibility
                        Don’t forget to install this library npm install play-sound
                      • You can see manual of play-sound library there
                        mZuil @bugsounet
                        Thanks to both of you!
                        I have just tried the code and it works in a js file, but when I try to replicate this code in the MMirror I get the error that opts is not defined. Where do I have to declare opts?
                          mZuil @mZuil
                          I am writing this code in the node_helper file
                            bugsounet Banned @mZuil
                            @mZuil post your part of module code, I have do see what you have done ;)
                              mZuil @bugsounet
                              @bugsounet It actually works!! :smiling_face_with_smiling_eyes: It happened because I was using the “use strict” directive, but without it, everything works as it should.
                              Wow, guys, you helped me a lot!! I will add you in the acknowledgement section of my final degree project hahaha :hugging_face:
                                @mZuil It’s better to add MagicMirror forum and not me, Thanks :)
                                because my signature says : I am not a reference in this forum
                                In all case i’m glade that works for you.
                                Happy use,
                                @bugsounet
