    Trouble playing audio file
    15 Posts 3 Posters 6.1k Views 3 Watching
      sdetweil @mZuil
      @mZuil can u run this piece of code from a terminal window?
      put the code in xxx.js
      then
      node xxx.js
      does it work?
        mZuil @sdetweil
        @sdetweil Sorry, I couldn’t try it before.
        It doesn’t work :( I am a beginner and I don’t understand well what is happening, could you help me, please? :crying_face:
          sdetweil @mZuil
          @mZuil what does the play() library say about sound output configuration?
          https://github.com/Marak/play.js#readme
          requirements:
          One of the CLI based audio player
          CLI means Command Line Interface
          I think you should have seen this error
                console.log('No suitable audio player could be found - exiting.'.red);
            sdetweil @mZuil
            @mZuil none of the players listed in his code and doc are installed on raspberry pi os by default.
            bugsounetB 1 Reply Last reply Reply Quote 0
            • bugsounetB
              bugsounet Banned @sdetweil
              @sdetweil the problem is not there…
              The problem is you can’t play a file when it’s not fully created!
              2 solutions:
              Make a promise
              Or play the file when the file is created
                sdetweil @bugsounet
                @bugsounet ah yes good catch. I jumped to play()…
                move the play() inside the callback on save()
                players will be the next problem
                bugsounetB 1 Reply Last reply Reply Quote 1
                • bugsounetB
                  just because sometime i'm kind... (my favorite sentence!)
                  Try this:
                  const gTTS = require('gtts');
                  var player = require('play-sound')(
                    opts = {
                      player: "mpg123" // use only `mpg123` for playing sounds
                  var gtts = new gTTS('text to speak', 'es-es');
                  // main file player
                  function playing (file) {
                    player.play(file, (err) => {
                      if (err) throw new Error(err)
                  gtts.save('/tmp/hello.wav', (err, result) => {
                    if(err) { throw new Error(err) }
                    console.log('Success! start playing result.');
                    // right ! sound file is created let's play it !
                    playing("/tmp/hello.wav");
                  Notes:
                  • You need to install mpg123 app with sudo apt-get install mpg123
                  • I replace your play library by play-sound for better compatibility
                    Don’t forget to install this library npm install play-sound
                  • You can see manual of play-sound library there
                    mZuil @bugsounet
                    Thanks to both of you!
                    I have just tried the code and it works in a js file, but when I try to replicate this code in the MMirror I get the error that opts is not defined. Where do I have to declare opts?
                      mZuil @mZuil
                      I am writing this code in the node_helper file
                      • bugsounetB
                        bugsounet Banned @mZuil
                        @mZuil post your part of module code, I have do see what you have done ;)
                          mZuil @bugsounet
                          @bugsounet It actually works!! :smiling_face_with_smiling_eyes: It happened because I was using the “use strict” directive, but without it, everything works as it should.
                          Wow, guys, you helped me a lot!! I will add you in the acknowledgement section of my final degree project hahaha :hugging_face:
                          • bugsounetB
                            @mZuil It’s better to add MagicMirror forum and not me, Thanks :)
                            because my signature says : I am not a reference in this forum
                            In all case i’m glade that works for you.
                            Happy use,
                            @bugsounet
