    Lost modules. Not showing after reinstall
    16 Posts 4 Posters 7.0k Views 4 Watching
    • N6NGN
      N6NG
      I had my MM working well… But all of a sudden when I modify one of the modules when I restart MM the module doesn’t show. I’ve had this happen with 6 of the 7 modules I had installed. Those I had installed were:
      Clock
      Calendar
      MMM-Remote-Control
      MMM-Weather
      MMM -WeatherForcast
      MMM-NewFeedTicker
      MMM-RAIN-RADAR
      MMM-Remote-Control
      The only one that returned after reinstalling was the MMM-WallPaper. I of course have rebooted and power off and on several times to no avail. All were working fine until I started modifying the position because they were cramped the way they were. I’m to the point where I am thinking I need to format the chip and start from scratch. But if I do that, I can’t help but think it will happen again.
      Anyone have an idea on what to try?
      Dennis
      N6NGN 1 Reply Last reply
      • N6NGN
        N6NG @N6NG
        @N6NG Well here is the story. I erased that module and started from scratch and put it back in. But it still didn’t show up on the MM. Here is what I found. In repositioning the individual screen locations they ended up overlaying other modules on the screen and rather than overlaying the visual of the other module it just didn’t show. When I went back and shrunk the size of the modules on the screen (going from ie: 400px by 400px to 200 px by 200 px it showed up again. I did this with other of the modules and they showed up again also. I haven’t finished all of them yet but I think it’s going to fix them all. I think that should solve all my invisible module problems.
        Dennis N6NG
        • N6NGN
          N6NG @N6NG
          @N6NG Just saw Sams reply to “@np27np27 want to see installers/upgrade.log” and will try that to see if it helps. I’ll report back .
            @N6NG you reinstalled??
            most of those modules are missing a dependent library
            see
            upgrade handles this for you. install does not, as the modules aren’t there yet
            • N6NGN
              N6NG @sdetweil
              @sdetweil Well I did ok until I started installing the MMM-RAIN-RADAR module again. Then I got this error message.
              Dennis Jacobson n6ngdennis@gmail.com
              4:07 PM (2 minutes ago)
              to Dennis
              pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ npm install MMM-RAIN-RADAR
              npm ERR! code E404
              npm ERR! 404 Not Found - GET https://registry.npmjs.org/MMM-RAIN-RADAR - Not found
              npm ERR! 404
              npm ERR! 404 ‘MMM-RAIN-RADAR@*’ is not in this registry.
              npm ERR! 404 This package name is not valid, because
              npm ERR! 404 1. name can no longer contain capital letters
              npm ERR! 404
              npm ERR! 404 Note that you can also install from a
              npm ERR! 404 tarball, folder, http url, or git url.
              npm ERR! /home/pi/.npm/_logs/2022-05-08T22_59_38_815Z-debug-0.log
              pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ cd MMM-RAIN-RADAR
              Dennis N6NG
                sdetweil @N6NG
                @N6NG that’s all wrong. you just npm install
                see the links in my signature below…
                • N6NGN
                  N6NG @sdetweil
                  @sdetweil followed the links and finally the npm install:
                  up to date, audited 1 package in 2s
                  found 0 vulnerabilities
                  to Dennis
                  npm ERR! code E404
                  npm ERR! 404
                  npm ERR! 404
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    mumblebaj Module Developer @N6NG
                    @N6NG Looks like you are doing an npm install MMM-RAIN-RADAR. This is not an npmjs module. In the ~/MagicMirror/modules folder you have to do a git clone https://github.com/jojoduquartier/MMM-RAIN-RADAR.git. From the github page doesn’t look like there are any dependencies to install afterward. Then just add module to you config.js and you should be good to go with it.
                      sdetweil @mumblebaj
                      @mumblebaj he had the git clone, just added the module name to the npm install for some reason…
                      he seems to have fixed that…
                      • mumblebajM
                        @sdetweil Ah ok. Module does not have any dependencies to install hence i thought he did it wrong way round.
                          sdetweil @mumblebaj
                          @mumblebaj no package.json, so nothing to do and nothing gets done
                          • N6NGN
                            N6NG @sdetweil
                            @sdetweil I did a git checkout package.json and this is what I got:
                            pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ git checkout package.json
                            error: pathspec ‘package.json’ did not match any file(s) known to git
                            pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ ls package.json
                            package.json
                            I started by doing an ls package.js in the MMM-RAIN-RADAR module and it listed it there. Then I did the checkout… What does that mean?
                              sdetweil @N6NG
                              @N6NG this module does not have a package.json
                              • N6NGN
                                N6NG @sdetweil
                                @sdetweil When I do a “ls package.json” is lists one in that module but I guess it could have come from somewhere else… I’ll delete the module and start again from scratch.
                                • N6NGN
                                  N6NG @N6NG
                                  Dennis N6NG
                                    sdetweil @N6NG
                                    @N6NG said in Lost modules. Not showing after reinstall:
                                    does that mean you changed the region layouts in css?
                                    • N6NGN
                                      N6NG @sdetweil
                                      @sdetweil Some of them yes… and some I just changed the config size options:
                                      dennis
