    Lost modules. Not showing after reinstall
    16 Posts 4 Posters 6.9k Views 4 Watching
      @N6NG you reinstalled??
      most of those modules are missing a dependent library
      see
      upgrade handles this for you. install does not, as the modules aren’t there yet
      N6NGN 1 Reply Last reply Reply Quote 0
      • N6NGN
        N6NG @sdetweil
        @sdetweil Well I did ok until I started installing the MMM-RAIN-RADAR module again. Then I got this error message.
        Dennis Jacobson n6ngdennis@gmail.com
        4:07 PM (2 minutes ago)
        to Dennis
        pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ npm install MMM-RAIN-RADAR
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/MMM-RAIN-RADAR - Not found
        npm ERR! 404
        npm ERR! 404 ‘MMM-RAIN-RADAR@*’ is not in this registry.
        npm ERR! 404 This package name is not valid, because
        npm ERR! 404 1. name can no longer contain capital letters
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR! /home/pi/.npm/_logs/2022-05-08T22_59_38_815Z-debug-0.log
        pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ cd MMM-RAIN-RADAR
        Dennis N6NG
          sdetweil @N6NG
          @N6NG that’s all wrong. you just npm install
          see the links in my signature below…
          • N6NGN
            N6NG @sdetweil
            @sdetweil followed the links and finally the npm install:
            up to date, audited 1 package in 2s
            found 0 vulnerabilities
            to Dennis
            npm ERR! code E404
            npm ERR! 404
            npm ERR! 404
            • mumblebajM
              mumblebaj Module Developer @N6NG
              @N6NG Looks like you are doing an npm install MMM-RAIN-RADAR. This is not an npmjs module. In the ~/MagicMirror/modules folder you have to do a git clone https://github.com/jojoduquartier/MMM-RAIN-RADAR.git. From the github page doesn’t look like there are any dependencies to install afterward. Then just add module to you config.js and you should be good to go with it.
                sdetweil @mumblebaj
                @mumblebaj he had the git clone, just added the module name to the npm install for some reason…
                he seems to have fixed that…
                • mumblebajM
                  @sdetweil Ah ok. Module does not have any dependencies to install hence i thought he did it wrong way round.
                    sdetweil @mumblebaj
                    @mumblebaj no package.json, so nothing to do and nothing gets done
                    N6NGN 1 Reply Last reply Reply Quote 1
                    • N6NGN
                      N6NG @sdetweil
                      @sdetweil I did a git checkout package.json and this is what I got:
                      pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ git checkout package.json
                      error: pathspec ‘package.json’ did not match any file(s) known to git
                      pi@raspberrypi:~/MagicMirror/modules/MMM-RAIN-RADAR $ ls package.json
                      package.json
                      I started by doing an ls package.js in the MMM-RAIN-RADAR module and it listed it there. Then I did the checkout… What does that mean?
                        sdetweil @N6NG
                        @N6NG this module does not have a package.json
                        • N6NGN
                          N6NG @sdetweil
                          @sdetweil When I do a “ls package.json” is lists one in that module but I guess it could have come from somewhere else… I’ll delete the module and start again from scratch.
                          • N6NGN
                            N6NG @N6NG
                            @N6NG Well here is the story. I erased that module and started from scratch and put it back in. But it still didn’t show up on the MM. Here is what I found. In repositioning the individual screen locations they ended up overlaying other modules on the screen and rather than overlaying the visual of the other module it just didn’t show. When I went back and shrunk the size of the modules on the screen (going from ie: 400px by 400px to 200 px by 200 px it showed up again. I did this with other of the modules and they showed up again also. I haven’t finished all of them yet but I think it’s going to fix them all. I think that should solve all my invisible module problems.
                            Dennis N6NG
                              sdetweil @N6NG
                              @N6NG said in Lost modules. Not showing after reinstall:
                              does that mean you changed the region layouts in css?
                              • N6NGN
                                N6NG @sdetweil
                                @sdetweil Some of them yes… and some I just changed the config size options:
                                dennis
