    Autostarts but doesn't run, will run on restart
    47 Posts 3 Posters 23.8k Views 3 Watching
      sdetweil @ember1205
      @ember1205 whatever script…
      if you used my setup script it uses the one already in installers
      E 1 Reply Last reply
      • E
        ember1205 @sdetweil
        Ok… Modified the ~/mm.sh script
        pm2 restart mm failed to start Chromium correctly - landed on the Chrome Desktop.
        Purged the config directory and started mm without issue.
        Restarted the mirror and everything came up clean multiple times, but there is clearly still something weird happening with Chromium in that I have to continue wiping the config directory before it will start up correctly.
          sdetweil @ember1205
          @ember1205 the new script wipes the config folder already
          E 2 Replies Last reply
          • E
            ember1205 @sdetweil
            Whatever it’s doing, it isn’t doing it correctly. “pm2 restart mm” lands me on the Chrome Desktop every time. I have to wipe the config folder by hand.
            • E
              ember1205 @sdetweil
              Its trying to wipe a non-existent directory
              0|mm  | + rm -rf /home/pi/.config/chromium-browser
              S 2 Replies Last reply
                sdetweil @ember1205
                @ember1205 ah. I ‘assumed’ folder name matched executable…doah…
                • E
                  ember1205 @sdetweil
                  @sdetweil said in Autostarts but doesn't run, will run on restart:
                  cd ~
                  rm -rf .config/chromium
                  rm -rf .config/electron
                  This was what you had mentioned earlier in the thread and worked, and it’s what I built my config wipe based on.
                    sdetweil @ember1205
                    @ember1205 do the curl again
                    • E
                      ember1205 @sdetweil
                      Seems to be working reliably. Even why I simply do a “shutdown now” without any of my shutdown process items, it starts up correctly.
                        sdetweil @ember1205
                        @ember1205 cool… thanks for the feedback…
                        i merged the changes into the master branch for all updates from now on
                        • E
                          ember1205 @sdetweil
                          Now I have to find something else to break… sigh… :)
                            sdetweil @ember1205
                            @ember1205 thanks!.. this exposed another problem , using the script on an ubuntu system it opened the MM page in the running chrome instance and THEN DIDN’T WAIT… so the script ‘failed’ and pm2 restarted it , over and over and over…
                            So, i just fixed THAT too… (didn’t break the prior! lol)
                            • E
                              ember1205 @sdetweil
                              As long as you got it all fixed, then it was a good day!
                              • 3 / 3
