    Update script not updating
    13 Posts 3 Posters 3.8k Views 3 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 update only does the base mm, no add on modules. those have their own procedures.
      on calendar, in either case the calendar.js of the base should have been restored, and then the update applied.
      if u still think there is an issue, email me the installers/upgrade.log
      same userid at gmail
        @ankonaskiff17 and the upgrade ONLY works if the mm versions are different
        if u are on 2.19, and current is 2.19, then nothing to do. you can ‘force’ it do do the apply, by using force as the parm instead of apply. this was added for the case where someone started a manual upgrade, but got stuck…
        but again, the script does not upgrade modules.
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
        • ankonaskiff17A Online
          ankonaskiff17 @sdetweil
          @sdetweil First thing I did with the MMM-Jast notification was to look if there was a section in the Readme about updating module but I think it was triggered externally.
          On Github the dates are older but there is this at very top, How do I address that?
            @ankonaskiff17 so in general, modules update with
            cd ~/MagicMirror/modules/module_folder
            git pull
            and if the module has a package.json, then
            npm install
            also in the module folder
              @sdetweil I found a different module with update instructions and did git pull in MMM-Jast but git pull yielded the following
              From https://github.com/jalibu/MMM-Jast
              5a5f781..8b771b6 main -> origin/main
              * [new tag] v2.6.3 -> v2.6.3
              Updating 5a5f781..8b771b6
              error: Your local changes to the following files would be overwritten by merge:
              package-lock.json
              Please commit your changes or stash them before you merge.
              Aborting
              pi@mirror:~/MagicMirror/modules/MMM-Jast $
                @ankonaskiff17 yeh, erase package-lock.json
                then git pull, npm install will update that file again
                  @sdetweil That is standard/typical of how to update a module?
                  Resolved notification
                    @ankonaskiff17 yes… no one should ship a package-lock.json as part of their release
                    this is only used by testing systems to make sure the environment is exact
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @sdetweil
                      @sdetweil actually the opposite is true, everyone should ship a lock file with its repository to ensure you will get the exact same dependencies that were tested with and not something newer which can introduce issues.
                      But if you just run npm install npm will update the lock file. So the effect is like not shipping a lock file at all.
                      Instead, you should use npm ci if there is a lock file https://docs.npmjs.com/cli/v8/commands/npm-ci. This makes sure that you have exactly the same dependencies no matter if there is a newer version available.
                        sdetweil @strawberry 3.141
                        @strawberry-3-141 however. not everyone runs the same platform as used during test, so all the parts change.
