    Update script not updating
    13 Posts 3 Posters 5.0k Views 3 Watching
    • ankonaskiff17A
      ankonaskiff17
      @sdetweil I used the scripts you provide but I’m having some issues and want to get some clarification so I don’t break the MM I just got running yesterday.
      First script is a run through but with no changes being applied
      Second script is same as first script but with apply attached to end of script which will update any modules or core components that are out of date is how I understand. Is that accurate?
      Also, what are ramifications of answering n to question below?
      I know what the mm.sh issue is and I caused it but it doesn’t cause any functional problems.
      installers/mm.sh
      modules/default/calendar/calendar.js
      do you want to save these files for later (Y/n)?
      I ran the second apply script but it doesn’t seem to be doing anything. I am getting a notification in top banner for update to MMM-Jast but it is not being found by the scripts.
      Shouldn’t calendar.js have been repaired? Shouldn’t it have picked up the MMM-Jast out of date?
      S 2 Replies Last reply
        sdetweil @ankonaskiff17
        @ankonaskiff17 update only does the base mm, no add on modules. those have their own procedures.
        on calendar, in either case the calendar.js of the base should have been restored, and then the update applied.
        if u still think there is an issue, email me the installers/upgrade.log
        same userid at gmail
          @ankonaskiff17 and the upgrade ONLY works if the mm versions are different
          if u are on 2.19, and current is 2.19, then nothing to do. you can ‘force’ it do do the apply, by using force as the parm instead of apply. this was added for the case where someone started a manual upgrade, but got stuck…
          but again, the script does not upgrade modules.
          ankonaskiff17A 1 Reply Last reply
          • ankonaskiff17A
            ankonaskiff17 @sdetweil
            @sdetweil First thing I did with the MMM-Jast notification was to look if there was a section in the Readme about updating module but I think it was triggered externally.
            On Github the dates are older but there is this at very top, How do I address that?
              @ankonaskiff17 so in general, modules update with
              cd ~/MagicMirror/modules/module_folder
              git pull
              and if the module has a package.json, then
              npm install
              also in the module folder
              • ankonaskiff17A
                @sdetweil I found a different module with update instructions and did git pull in MMM-Jast but git pull yielded the following
                From https://github.com/jalibu/MMM-Jast
                5a5f781..8b771b6 main -> origin/main
                * [new tag] v2.6.3 -> v2.6.3
                Updating 5a5f781..8b771b6
                error: Your local changes to the following files would be overwritten by merge:
                package-lock.json
                Please commit your changes or stash them before you merge.
                Aborting
                pi@mirror:~/MagicMirror/modules/MMM-Jast $
                  @ankonaskiff17 yeh, erase package-lock.json
                  then git pull, npm install will update that file again
                  • ankonaskiff17A
                    @sdetweil That is standard/typical of how to update a module?
                    Resolved notification
                      @ankonaskiff17 yes… no one should ship a package-lock.json as part of their release
                      this is only used by testing systems to make sure the environment is exact
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @sdetweil
                        @sdetweil actually the opposite is true, everyone should ship a lock file with its repository to ensure you will get the exact same dependencies that were tested with and not something newer which can introduce issues.
                        But if you just run npm install npm will update the lock file. So the effect is like not shipping a lock file at all.
                        Instead, you should use npm ci if there is a lock file https://docs.npmjs.com/cli/v8/commands/npm-ci. This makes sure that you have exactly the same dependencies no matter if there is a newer version available.
                          sdetweil @strawberry 3.141
                          @strawberry-3-141 however. not everyone runs the same platform as used during test, so all the parts change.
                          • strawberry 3.141S
                            @sdetweil the hardware might be different but at least the code and dependencies are the same which increases the chances to reproduce and fix the issue
                              @strawberry-3-141 but thats not true
                              on intel I get one version
                              on arm (32bit) I get a diffferent version
                              on arm (64bit) I get a different version
                              on aarch64 i get a different version
                              especially if there is a binary… and who knows what is buried under there
