    How to fix npm install errors on Gateway?
    gatewaynpmerror
    2 Posts 4 Posters 1.4k Views 4 Watching
    • U Offline
      Untitled
      I’m trying to install MagicMirror on Raspbian.
      However, after installing the Gateway to control the EXT-detector and entering npm install to install npm there, the following error appears.
      I tried reinstalling the OS itself for this, but the result was the same.
      Is there any other way?
      An unhandled error occurred inside electron-rebuild
      node-gyp failed to rebuild '/home/raspberry/MagicMirror/modules/Gateway/node_modules/node-pty'.
      Error: `make` failed with exit code: 2
      Error: node-gyp failed to rebuild '/home/raspberry/MagicMirror/modules/Gateway/node_modules/node-pty'.
          at ModuleRebuilder.rebuildNodeGypModule (/home/raspberry/MagicMirror/modules/Gateway/node_modules/magicmirror-rebuild/build/module-rebuilder.js:193:19)
          at processTicksAndRejections (internal/process/task_queues.js:95:5)
          at async Rebuilder.rebuildModuleAt (/home/raspberry/MagicMirror/modules/Gateway/node_modules/magicmirror-rebuild/build/rebuild.js:180:9)
          at async Rebuilder.rebuild (/home/raspberry/MagicMirror/modules/Gateway/node_modules/magicmirror-rebuild/build/rebuild.js:143:17)
          at async /home/raspberry/MagicMirror/modules/Gateway/node_modules/magicmirror-rebuild/build/cli.js:141:9
      AssassinsA 1 Reply Last reply Reply Quote 0
      • AssassinsA Offline
        Assassins @Untitled
        @Untitled
        Is not the right Forum.
        Ask here : https://forum.bugsounet.fr
