    Default weather module not showing after MM update
    25 Posts 7 Posters 11.6k Views 7 Watching
    • 0 Offline
      01ZerosOnes01
      I keep the mirror updated so I am assuming it was updated from the last version.
      I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
      followed by git stash apply
      All other default and third party modules work.
      Thank for your help it is appreciated.
      • mumblebajM Offline
        mumblebaj Module Developer @01ZerosOnes01
        @01ZerosOnes01 I had my API authorized and the module works just fine with your location data. The only change I made was not add quotes around the locationID.
        locationID: 4891010,
        Jarhead96097J 1 Reply Last reply Reply Quote 0
        • Jarhead96097J Offline
          Jarhead96097 @sdetweil
          @sdetweil I also upgraded from 2.19.0, which had been upgraded from 2.18.0. No problems before today.
          Jarhead96097
            Jarhead96097 @mumblebaj
            @mumblebaj Well, unfortunately, removing the quotes around locationID did not resolve the issue on my configuration. I still receive “Uncaught SyntaxError: Unexpected token” in weather.js:159.
            Jarhead96097
            • 0 Offline
              01ZerosOnes01
              Raspberry Pi 4 2GB
              Well this is what i have done so far.
              Removed SD card with broken default weather module.
              With new SD card installed fresh 64bit Pi OS
              Fresh manual install of MagicMirror
              “name”: “magicmirror”,
              “version”: “2.20.0”,
              “description”: “The open source modular smart mirror platform.”,
              “main”: “js/electron.js”,
              Entered my openweathermap credentials
              and
              Walla! the weather module works.
              I have no idea why the weather module broke after the MagicMirror update. I will be following this thread to see if it is a problem or it was just a fluke.
              Good luck and thanks to all that contribute.
              Now I just have to reload my third party modules and customizations.
                Jarhead96097 @01ZerosOnes01
                @01ZerosOnes01 @sdetweil Glad to hear you’re up and running on a fresh install… I’m hoping to avoid having to rebuild mine. Any other thoughts?
                And thanks for your time in advance!
                Jarhead96097
                S 0 2 Replies Last reply Reply Quote 0
                  sdetweil @Jarhead96097
                  @Jarhead96097 would be interested in knowing if my upgrade script avoided this problem
                  FoziF 1 Reply Last reply Reply Quote 1
                    Bearded1ne253 @01ZerosOnes01
                    @01ZerosOnes01 you do not have a “ to start your string, only one at the end…
                    • 0 Offline
                      01ZerosOnes01 @Jarhead96097
                      @Jarhead96097 I was lucky I had a backup of my config. So just a reinstall and copy and paste. Everything is working fine now.
                      All the best.
                      • FoziF Offline
                        Fozi Project Sponsor @sdetweil
                        @sdetweil I updated with your script and had no issues at all. Everything is fine.
                        • T Offline
                          Trabi11 @01ZerosOnes01
                          @01ZerosOnes01 said in Default weather module not showing after MM update:
                          @mumblebaj Okay this is what I get when I run shift + ctrl + i
                          Load script: modules/default/weather/weather.js
                          :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
                          I’m running into the exact same issue as explained above since I updated my MM.
                          However, I only get this error message in chromium on the rasperry pi itself when I call the URL of the MM. All other devices in my network can display the Weather Module cleanly when I access the page via LAN IP. Both chromium and firefox on my notebook and my smartphone are displaying the default weather module cleanly.
