    Default weather module not showing after MM update
    25 Posts 7 Posters 11.8k Views 7 Watching
    • 0
      01ZerosOnes01 @Jarhead96097
      @Jarhead96097 Thanks for your info. Hopefully someone can come up with the fix.
      mumblebajM 1 Reply Last reply
        sdetweil @01ZerosOnes01
        @01ZerosOnes01 @Jarhead96097
        how did u upgrade,and from what version?
        I don’t see any significant code change here this release…
        Jarhead96097J 1 Reply Last reply
        • 0
          01ZerosOnes01
          I keep the mirror updated so I am assuming it was updated from the last version.
          I updated by first issuing git stash then git pull && npm install --only=prod --omit=dev
          followed by git stash apply
          All other default and third party modules work.
          Thank for your help it is appreciated.
          • mumblebajM
            mumblebaj Module Developer @01ZerosOnes01
            @01ZerosOnes01 I had my API authorized and the module works just fine with your location data. The only change I made was not add quotes around the locationID.
            locationID: 4891010,
            • Jarhead96097J
              Jarhead96097 @sdetweil
              @sdetweil I also upgraded from 2.19.0, which had been upgraded from 2.18.0. No problems before today.
              Jarhead96097
              • Jarhead96097J
                Jarhead96097 @mumblebaj
                @mumblebaj Well, unfortunately, removing the quotes around locationID did not resolve the issue on my configuration. I still receive “Uncaught SyntaxError: Unexpected token” in weather.js:159.
                Jarhead96097
                • 0
                  01ZerosOnes01
                  Raspberry Pi 4 2GB
                  Well this is what i have done so far.
                  Removed SD card with broken default weather module.
                  With new SD card installed fresh 64bit Pi OS
                  Fresh manual install of MagicMirror
                  “name”: “magicmirror”,
                  “version”: “2.20.0”,
                  “description”: “The open source modular smart mirror platform.”,
                  “main”: “js/electron.js”,
                  Entered my openweathermap credentials
                  and
                  Walla! the weather module works.
                  I have no idea why the weather module broke after the MagicMirror update. I will be following this thread to see if it is a problem or it was just a fluke.
                  Good luck and thanks to all that contribute.
                  Now I just have to reload my third party modules and customizations.
                  • Jarhead96097J
                    Jarhead96097 @01ZerosOnes01
                    @01ZerosOnes01 @sdetweil Glad to hear you’re up and running on a fresh install… I’m hoping to avoid having to rebuild mine. Any other thoughts?
                    And thanks for your time in advance!
                    Jarhead96097
                    S 0 2 Replies Last reply
                      sdetweil @Jarhead96097
                      @Jarhead96097 would be interested in knowing if my upgrade script avoided this problem
                      FoziF 1 Reply Last reply
                        Bearded1ne253 @01ZerosOnes01
                        @01ZerosOnes01 you do not have a “ to start your string, only one at the end…
                        • 0
                          @Jarhead96097 I was lucky I had a backup of my config. So just a reinstall and copy and paste. Everything is working fine now.
                          All the best.
                          • FoziF
                            Fozi Project Sponsor @sdetweil
                            @sdetweil I updated with your script and had no issues at all. Everything is fine.
                            • T
                              Trabi11 @01ZerosOnes01
                              @01ZerosOnes01 said in Default weather module not showing after MM update:
                              @mumblebaj Okay this is what I get when I run shift + ctrl + i
                              Load script: modules/default/weather/weather.js
                              :8080/modules/default/weather/weather.js:159 Uncaught SyntaxError: Unexpected token .
                              I’m running into the exact same issue as explained above since I updated my MM.
                              However, I only get this error message in chromium on the rasperry pi itself when I call the URL of the MM. All other devices in my network can display the Weather Module cleanly when I access the page via LAN IP. Both chromium and firefox on my notebook and my smartphone are displaying the default weather module cleanly.
