    MMM-Sonos no Cover
    11 Posts 3 Posters 3.5k Views 3 Watching
    • W
      wuermchen
      Hi
      I ran the MM update to v2.20. Since then, Sonos hasn’t shown a cover anymore. Only the placeholder can be seen on the Magicmirror.Unbenannt.JPG
      But via firefox http://192.168.178.100:8080/ you can see the cover. Can someone help me?Screenshot 2022-07-20 at 15-29-13 MagicMirror².png
      karsten13K S 2 Replies Last reply Reply Quote 0
      • karsten13K
        karsten13 @wuermchen
        @wuermchen
        address, not adress
        • karsten13K
          @wuermchen
          may a cors problem.
          Are there errors in the dev console?
            sdetweil @wuermchen
            @wuermchen ctrl-shift-i,
            select the console tab
            • W
              wuermchen
              Hello, Yes the MM shows errors.
              • karsten13K
                @wuermchen
                you can try to change the address in config.js from 0.0.0.0 to the ip address of your pi.
                • W
                  wuermchen
                  I just found that out too.
                  Unfortunately, access via the web browser no longer works.
                    sdetweil @wuermchen
                    @wuermchen you have to use the IP address to get to that mirror now.
                    • W
                      wuermchen
                      I entered the RaspberryPi address, the MM starts with a cover.
                      But then I have no access via the web browser
                      S karsten13K 2 Replies Last reply Reply Quote 0
                        sdetweil @wuermchen
                        @wuermchen where is the browser running?
                        is the IP address on a guest network?
                        • karsten13K
                          @wuermchen
                          address, not adress
                          • W
                            wuermchen
                            Excellent! That’s the problem. Many Thanks
