MMM-Sonos no Cover
Hi
I ran the MM update to v2.20. Since then, Sonos hasn’t shown a cover anymore. Only the placeholder can be seen on the Magicmirror.
But via firefox http://192.168.178.100:8080/ you can see the cover. Can someone help me?
address, notadress -
@wuermchen ctrl-shift-i,
select the console tab -
Hello, Yes the MM shows errors.
you can try to change the
addressinconfig.jsfrom0.0.0.0to the ip address of your pi. -
I just found that out too.
Unfortunately, access via the web browser no longer works. -
@wuermchen you have to use the IP address to get to that mirror now.
I entered the RaspberryPi address, the MM starts with a cover.
But then I have no access via the web browser
@wuermchen where is the browser running?
is the IP address on a guest network?
Excellent! That’s the problem. Many Thanks
