    MMM-Sonos no Cover
    11 Posts 3 Posters 3.6k Views 3 Watching
    • karsten13K
      karsten13 @wuermchen
      @wuermchen
      may a cors problem.
      Are there errors in the dev console?
        sdetweil @wuermchen
        @wuermchen ctrl-shift-i,
        select the console tab
        • W
          wuermchen
          Hello, Yes the MM shows errors.
          karsten13K 1 Reply Last reply
          • karsten13K
            @wuermchen
            you can try to change the address in config.js from 0.0.0.0 to the ip address of your pi.
            • W
              wuermchen
              I just found that out too.
              Unfortunately, access via the web browser no longer works.
                sdetweil @wuermchen
                @wuermchen you have to use the IP address to get to that mirror now.
                • W
                  wuermchen
                  I entered the RaspberryPi address, the MM starts with a cover.
                  But then I have no access via the web browser
                  S karsten13K 2 Replies Last reply
                    sdetweil @wuermchen
                    @wuermchen where is the browser running?
                    is the IP address on a guest network?
                    • karsten13K
                      @wuermchen
                      address, not adress
                      • W
                        wuermchen
                        Excellent! That’s the problem. Many Thanks
