    I think I Broke my MagicMirror
    7 Posts 4 Posters 976 Views 4 Watching
    • plainbrokeP Offline
      plainbroke
      My MagicMirror was working and I was doing some customizing of the css ect. all went as planned. UNTIL, I ran “sudo apt-get update && sudo apt-get upgrade -y” and when it was finished, “sudo reboot” Now I cannot get MM to start.
      So I ran “npm outdated” and found electron missing.
      So I found bugsounets electron install on GitHub.
      “npm install magicmirror-rebuild --save” and ran it.
      another “sudo reboot” still cannot get MM to start. pm2 shows it loaded and when I go into VNC , Using ctrl+m I see , electron instead of MagicMirror is minimised. What did I do wrong this is a fresh install a couple days ago.
      pi@MM:~/MagicMirror $ npm -v
      8.11.0
      pi@MM:~/MagicMirror $ node -v
      v16.16.0
      pi@MM:~/MagicMirror $ npx electron -v
      v19.0.9
      Here are my electron, npm and node versions.
      HELP…
        plainbroke @sdetweil
        @sdetweil Well that got me no where. I still have the black screen and when I ctrl+m it says electron instead of MagicMirror.
        So I just renamed MagicMirror to MM and reinstalled with your script I have the backup restore module saved so I can reinstall my modules quickly and with minimal effort. The mirror looks better already…
        BKeyportB S 2 Replies Last reply Reply Quote 0
          sdetweil @plainbroke
          @plainbroke yeesh…
          don’t run upgrades unless you know how to work thru the issues.
          MagicMirror-rebuild is for some modules. not the base.
          do this
          stop MagicMirror
          cd ~
          rm -rf .config/Electron
          note the dot in front of config
          then run my upgrade script w
          force
          as the parameter, instead of apply
          see
          it does all the steps (not mm-rebuild tho)
            • BKeyportB Offline
              BKeyport Module Developer @plainbroke
              @plainbroke I would, at this point, back up your custom files, (config.js and custom.css), then delete and reinstall, or reformat and install on a fresh OS install.
                @plainbroke can u send me the MM/installers/upgrade.log
                if u still have it
                same userid at gmail.
                glad u got it running again
                  I went all out and started fresh, I have the backups of all files that are not “default”. My modified files are backed up to 3 places after having an issue when my OpenMediaVault somehow became corrupted. Now I run a simple Samba file server. Really all I needed in the first place. Short answer is I wiped it SSD drive, so no upgrade.log to send you.
                    plainbroke @plainbroke
                    @plainbroke
                    reloading 36 modules and getting them all to work as expected ,takes some time. Almost there today. MMM-RSTPStream is being difficult not wanting to play nice with vlc for some reason this round… Guess 5 different instances is too many. eventhough I have them spread out in the list of modules that carousel runs for me…
