    CSS Help
    18 Posts 3 Posters 6.2k Views 3 Watching
      sdetweil @BKeyport
      @BKeyport so you could use code to fiddle w the styles.
      https://www.w3schools.com/jsref/met_document_getelementsbyclassname.asp
      you want it on .container under region top bar
      not on top bar itself… else everything will be affected
      BKeyportB 1 Reply Last reply
      • BKeyportB
        @sdetweil Exactly, I can’t seem to get far enough in custom.css
        .region.top.bar.container don’t work, etc. The problem seems to be the style is hardcoded, perhaps, but I have no idea where.
          sdetweil @BKeyport
          @BKeyport when there is no space between classes it means has all
          but this is split over 2 tags
          div .region.top.bar
          div .container
          • BKeyportB
            @sdetweil So, how would I get down to container, and restrict it to within the top bar?
              sdetweil @BKeyport
              @BKeyport in css you can’t as it selects all
              using code you can, cause u can change one element
                shin10 Module Developer
                Just use
                .region.top.bar .module {
                    display: inline-block;
                or even better, explicitly the modules you want in one line (to avoid notifications shifting everything to the left in case they pop up)
                .MMM-FlipClock, .MMM-Worldclock {
                (*oops - edited)
                • BKeyportB
                  BKeyport Module Developer @shin10
                  @shin10 2nd option is near perfect! Thanks! (changed it to inline-flex, and it lines up correct)
                    sdetweil @BKeyport
                    @BKeyport but you asked to modify top_bar, not your module…
                    • BKeyportB
                      @sdetweil True, because I didn’t know the solution was to specify per-module.
                        sdetweil @BKeyport
                        @BKeyport ah , requirements… lol
                        • BKeyportB
                          Devil in the details, again. :)
