    pm2 and MagicMirror stopped
    11 Posts 2 Posters 3.6k Views 2 Watching
    • N6NGN Offline
      N6NG
      I don’t think I did anything to cause it but all of a sudden when I do pm2 start MagicMirror it says that pm2 has started MagicMirror but that is as far as it gets. The panel says status is online and memory using 2.6mb but the mirror never starts. I’ve rebooted, I’ve shutdown and started from scratch and nothing seems to help… I tried to do a search on not starting but must not have asked the right question.
      Anyone ever have this problem?
      Dennis
        sdetweil @N6NG
        @N6NG show the messages
        pm2 logs --lines=50
          @sdetweil also, do
          pm2 stop all
          then
          npm start
          • N6NGN Offline
            N6NG
            pi@raspberrypi:~/MagicMirror $ npm stop all
            npm ERR! Missing script: “stop”
            npm ERR!
            npm ERR! To see a list of scripts, run:
            npm ERR! npm run
            npm ERR! /home/pi/.npm/_logs/2022-08-05T23_00_11_817Z-debug-0.log
              sdetweil @N6NG
              @N6NG pm2 stop all
              • N6NGN Offline
                N6NG
                That is what I got when i did a pm2 stop all.
                  sdetweil @N6NG
                  @N6NG no, you pasted that you did npm stop all, which is not valid
                  pm2
                  is not the same as
                  npm
                  • N6NGN Offline
                    N6NG
                    /MagicMirror $ npm start
                    magicmirror@2.20.0 start
                    /tmp/start-adaafac7.sh: 1: /tmp/start-adaafac7.sh: ./node_modules/.bin/electron: not found
                      sdetweil @N6NG
                      @N6NG fun
                      do
                      grep \"electron\": package.json
                      it will display line like
                      	"electron": "^19.0.6"
                      then do
                      npm install electron@19.0.6
                      whatever the number is
                      then test with npm start again
                      • N6NGN Offline
                        N6NG
                        @sdetweil When I did the grep "electron":package.json it just sat and looked back at me for 5 minutes. So I canceled it and just did the npm install electron@19.0.0 and it installed just fine. Then I did npm start and it started the MagigMirror properly. So I’m guessing Iost the electron somehow. but I stopped MagicMirror and started it again with pm2 start MagicMirror and it worked fine…
                        Thank you Sam… I thought I had you there for a moment… I should have known better…
                        Dennis :)
                        I see the \ mark got dropped from my message after the word electron but it was there when I typed it .
                          sdetweil @N6NG
                          @N6NG you had to do the grep exactly Iike it I typed it, else it will return nothing…
