    pm2 and MagicMirror stopped
    11 Posts 2 Posters 3.2k Views 2 Watching
      @sdetweil also, do
      pm2 stop all
      then
      npm start
      • N6NGN Offline
        N6NG
        pi@raspberrypi:~/MagicMirror $ npm stop all
        npm ERR! Missing script: “stop”
        npm ERR!
        npm ERR! To see a list of scripts, run:
        npm ERR! npm run
        npm ERR! /home/pi/.npm/_logs/2022-08-05T23_00_11_817Z-debug-0.log
          sdetweil @N6NG
          @N6NG pm2 stop all
          • N6NGN Offline
            N6NG
            That is what I got when i did a pm2 stop all.
              sdetweil @N6NG
              @N6NG no, you pasted that you did npm stop all, which is not valid
              pm2
              is not the same as
              npm
              • N6NGN Offline
                N6NG
                /MagicMirror $ npm start
                magicmirror@2.20.0 start
                /tmp/start-adaafac7.sh: 1: /tmp/start-adaafac7.sh: ./node_modules/.bin/electron: not found
                  sdetweil @N6NG
                  @N6NG fun
                  do
                  grep \"electron\": package.json
                  it will display line like
                  	"electron": "^19.0.6"
                  then do
                  npm install electron@19.0.6
                  whatever the number is
                  then test with npm start again
                  • N6NGN Offline
                    N6NG
                    @sdetweil When I did the grep "electron":package.json it just sat and looked back at me for 5 minutes. So I canceled it and just did the npm install electron@19.0.0 and it installed just fine. Then I did npm start and it started the MagigMirror properly. So I’m guessing Iost the electron somehow. but I stopped MagicMirror and started it again with pm2 start MagicMirror and it worked fine…
                    Thank you Sam… I thought I had you there for a moment… I should have known better…
                    Dennis :)
                    I see the \ mark got dropped from my message after the word electron but it was there when I typed it .
                      sdetweil @N6NG
                      @N6NG you had to do the grep exactly Iike it I typed it, else it will return nothing…
