    I want to display txt files from outside at the bottom
    30 Posts 2 Posters 9.9k Views 3 Watching
    • 史 Offline
      史新瑞
      Display the text from the external TXT file at the bottom instead of the text given in config.js
      史 S 2 Replies Last reply Reply Quote 0
      • 史 Offline
        史新瑞 @史新瑞
        https://github.com/DanielHabenicht/MMM-json
        Is this all right?
          sdetweil @史新瑞
          @史新瑞 I do not understand your question
          display text files at the bottom?
          text from outside?
          史 1 Reply Last reply Reply Quote 0
          • 史 Offline
            史新瑞 @sdetweil
            @sdetweil Display the text stored in another TXT file at the bottom. This TXT file is not related to magicirror
              sdetweil @史新瑞
              @史新瑞 ok, maybe
              MMM-SimpleText
              from the 3rd party modules list
              https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules
              史 2 Replies Last reply Reply Quote 0
              • 史 Offline
                史新瑞 @sdetweil
                @sdetweil Thank you very much. I didn’t find it yesterday
                • 史 Offline
                  史新瑞 @sdetweil
                  @sdetweil After installing this module, NPM Run Server is normal and NPM Run Start cannot be used
                    sdetweil @史新瑞
                    @史新瑞 show messages
                    • 史 Offline
                      史新瑞 @sdetweil
                      @sdetweil There is no error message
                        sdetweil @史新瑞
                        @史新瑞 if npm start doesn’t work, show me ALL the messages
                        • 史 Offline
                          史新瑞 @sdetweil
                          @sdetweil Is it the information in the terminal
                            sdetweil @史新瑞
                            @史新瑞 yes… you can redirect that to a file
                            npm start >somefile.txt 2>&1
                            wait…
                            then ctrl-c
                            then examine and post
                            make sure to pm2 stop all before npm start
                            • 史 Offline
                              史新瑞 @sdetweil
                              • 史 Offline
                                史新瑞 @sdetweil
                                @sdetweil Sorry, I can’t find the document you said.
                                  sdetweil @史新瑞
                                  @史新瑞 you must create it with the redirection operator >
                                  same as windows. you can capture the output of a command to a file
                                  • 史 Offline
                                    史新瑞 @sdetweil
                                    @sdetweil npm ERR! code ENOENT
                                    npm ERR! syscall open
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR! /home/pi/.npm/_logs/2022-08-14T14_09_00_102Z-debug-0.log
                                      sdetweil @史新瑞
                                      @史新瑞 again, not in the MagicMirror folder
                                      • 史 Offline
                                        史新瑞 @sdetweil
                                        @sdetweil Thank you for your patient guidance
                                        npm ERR! errno -2
                                        npm ERR! enoent
                                        npm ERR! /home/pi/.npm/_logs/2022-08-14T14_13_06_562Z-debug-0.log
                                          sdetweil @史新瑞
                                          @史新瑞 still not in the MagicMirror folder
                                          npm start
                                          • 史 Offline
                                            史新瑞 @sdetweil
                                            @sdetweil Sorry, I misunderstood what you said just now
