    I want to display txt files from outside at the bottom
    30 Posts 2 Posters 10.1k Views 3 Watching
    • 史 Offline
      史新瑞 @sdetweil
      @sdetweil Is it the information in the terminal
        sdetweil @史新瑞
        @史新瑞 yes… you can redirect that to a file
        npm start >somefile.txt 2>&1
        wait…
        then ctrl-c
        then examine and post
        make sure to pm2 stop all before npm start
        史 2 Replies Last reply Reply Quote 0
        • 史 Offline
          史新瑞 @sdetweil
          • 史 Offline
            史新瑞 @sdetweil
            @sdetweil Sorry, I can’t find the document you said.
              sdetweil @史新瑞
              @史新瑞 you must create it with the redirection operator >
              same as windows. you can capture the output of a command to a file
              史 1 Reply Last reply Reply Quote 0
              • 史 Offline
                史新瑞 @sdetweil
                @sdetweil npm ERR! code ENOENT
                npm ERR! syscall open
                npm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                npm ERR! enoent This is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR! /home/pi/.npm/_logs/2022-08-14T14_09_00_102Z-debug-0.log
                  sdetweil @史新瑞
                  @史新瑞 again, not in the MagicMirror folder
                  • 史 Offline
                    史新瑞 @sdetweil
                    @sdetweil Thank you for your patient guidance
                    npm ERR! errno -2
                    npm ERR! enoent
                    npm ERR! /home/pi/.npm/_logs/2022-08-14T14_13_06_562Z-debug-0.log
                      sdetweil @史新瑞
                      @史新瑞 still not in the MagicMirror folder
                      npm start
                      • 史 Offline
                        史新瑞 @sdetweil
                        @sdetweil Sorry, I misunderstood what you said just now
                          sdetweil @史新瑞
                          @史新瑞 MagicMirror is installed in a subfolder named MagicMirror
                          the npm command reads the package.json file in the CURRENT folder to determine what to do
                          npm means node package manager (n.p.m.)
                          you are in the users home folder
                          /home/pi
                          no package.json here…
                          you must change the current directory (cd command)
                            @史新瑞 said in I want to display txt files from outside at the bottom:
                            start > somefile Txt
                            you are missing the . somefile.txt
                            also Linux is case sensitive
                            so somefile.Txt is not the same as somefile.txt
                            • 史 Offline
                              史新瑞 @sdetweil
                              magicmirror@2.20.0 start
                              [14.08.2022 22:18.26.091] [LOG] Starting MagicMirror: v2.20.0
                              [14.08.2022 22:18.26.095] [LOG] Loading config …
                              [14.08.2022 22:18.26.106] [LOG] Loading module helpers …
                              [14.08.2022 22:18.26.109] [LOG] No helper found for module: alert.
                              [14.08.2022 22:18.26.120] [LOG] Initializing new module helper …
                              [14.08.2022 22:18.26.120] [LOG] Module helper loaded: updatenotification
                              [14.08.2022 22:18.26.122] [LOG] No helper found for module: clock.
                              [14.08.2022 22:18.26.430] [LOG] Initializing new module helper …
                              [14.08.2022 22:18.26.431] [LOG] Module helper loaded: calendar
                              [14.08.2022 22:18.26.432] [LOG] No helper found for module: weather.
                              [14.08.2022 22:18.26.916] [LOG] Initializing new module helper …
                              [14.08.2022 22:18.26.917] [LOG] Module helper loaded: MMM-ImagesPhotos
                              [14.08.2022 22:18.26.918] [LOG] No helper found for module: helloworld.
                              [14.08.2022 22:18.26.919] [LOG] No helper found for module: MMM-SimpleText.
                              [14.08.2022 22:18.26.919] [LOG] All module helpers loaded.
                              [14.08.2022 22:18.27.092] [LOG] Starting server on port 8080 …
                              [14.08.2022 22:18.27.115] [LOG] Server started …
                              [14.08.2022 22:18.27.116] [LOG] Connecting socket for: updatenotification
                              [14.08.2022 22:18.27.117] [LOG] Starting module helper: updatenotification
                              [14.08.2022 22:18.27.117] [LOG] Connecting socket for: calendar
                              [14.08.2022 22:18.27.118] [LOG] Starting node helper for: calendar
                              [14.08.2022 22:18.27.118] [LOG] Connecting socket for: MMM-ImagesPhotos
                              [14.08.2022 22:18.27.119] [LOG] Starting node helper for: MMM-ImagesPhotos
                              [14.08.2022 22:18.27.119] [LOG] Sockets connected & modules started …
                              [14.08.2022 22:18.27.400] [LOG] Launching application.
                              [14.08.2022 22:18.29.770] [LOG] Create new calendarfetcher for url:
                              [14.08.2022 22:18.29.871] [INFO] Checking git for module: MMM-ImagesPhotos
                              [14.08.2022 22:18.29.965] [INFO] Checking git for module: MMM-SimpleText
                              [14.08.2022 22:18.29.985] [INFO] Checking git for module: default
                              [14.08.2022 22:18.32.381] [INFO] Calendar-Fetcher: Broadcasting 6 events.
                                @史新瑞 also u didnt show me contents of MagicMirror folder… you showed user root
                                /home/pi
                                • 史 Offline
                                  史新瑞 @sdetweil
                                  • 史 Offline
                                    史新瑞 @sdetweil
                                    @sdetweil Thank you, sir. Is my problem easy to solve? In addition, it’s nearly 23 o’clock here, so I will turn off my computer and use my mobile phone to receive your messages. However, in this way, I will not be able to correct it as quickly as possible according to your method
                                      sdetweil @史新瑞
                                      @史新瑞 i just installed the module…
                                      can u show me the config.js for this?
                                      the filePath parm is assuming the file is located in the same module folder…
                                      • 史 Offline
                                        史新瑞 @sdetweil
                                        @sdetweil Sorry, I can’t show it to you now, because my mother doesn’t allow me to use the computer at this time in the evening. It is already 12 o 'clock here, so I can only send it to you tomorrow morning, that is, August 15, around 9 o 'clock in Dong8 district. I am very sorry, and thank you very much for your guidance
                                          sdetweil @史新瑞
                                          @史新瑞 no problem
                                          here is my test config.js
                                           	module: 'MMM-SimpleText',
                                           	position: 'top_center',
                                          			text: {
                                          			  'value': 'Hello World!'
                                          			fontURL: {
                                          			  'value': 'Tahoma, Geneva, sans-serif'
                                          			fontSize: {
                                          			  'value': 'xx-large'
                                          			fontStyle: {
                                          			  'value': 'italic'
                                          			color: {
                                          			  'value': '#FFFFFF'
                                          			filePath: {
                                          				'value':"../../config/config.js"
                                          and a screen shot
                                          • 史 Offline
                                            史新瑞 @sdetweil
                                            @sdetweil Thank you, but my problem now is that the weather module is not working properly
