    I want to display txt files from outside at the bottom
    30 Posts 2 Posters 11.4k Views 3 Watching
    • 史
      史新瑞 @sdetweil
      • 史
        史新瑞 @sdetweil
        @sdetweil Sorry, I can’t find the document you said.
          sdetweil @史新瑞
          @史新瑞 you must create it with the redirection operator >
          same as windows. you can capture the output of a command to a file
          史 1 Reply Last reply
          • 史
            史新瑞 @sdetweil
            @sdetweil npm ERR! code ENOENT
            npm ERR! syscall open
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
            npm ERR! enoent This is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR! /home/pi/.npm/_logs/2022-08-14T14_09_00_102Z-debug-0.log
              sdetweil @史新瑞
              @史新瑞 again, not in the MagicMirror folder
              • 史
                史新瑞 @sdetweil
                @sdetweil Thank you for your patient guidance
                npm ERR! errno -2
                npm ERR! enoent
                npm ERR! /home/pi/.npm/_logs/2022-08-14T14_13_06_562Z-debug-0.log
                  sdetweil @史新瑞
                  @史新瑞 still not in the MagicMirror folder
                  npm start
                  • 史
                    史新瑞 @sdetweil
                    @sdetweil Sorry, I misunderstood what you said just now
                      sdetweil @史新瑞
                      @史新瑞 MagicMirror is installed in a subfolder named MagicMirror
                      the npm command reads the package.json file in the CURRENT folder to determine what to do
                      npm means node package manager (n.p.m.)
                      you are in the users home folder
                      /home/pi
                      no package.json here…
                      you must change the current directory (cd command)
                        @史新瑞 said in I want to display txt files from outside at the bottom:
                        start > somefile Txt
                        you are missing the . somefile.txt
                        also Linux is case sensitive
                        so somefile.Txt is not the same as somefile.txt
                        • 史
                          史新瑞 @sdetweil
                          magicmirror@2.20.0 start
                          [14.08.2022 22:18.26.091] [LOG] Starting MagicMirror: v2.20.0
                          [14.08.2022 22:18.26.095] [LOG] Loading config …
                          [14.08.2022 22:18.26.106] [LOG] Loading module helpers …
                          [14.08.2022 22:18.26.109] [LOG] No helper found for module: alert.
                          [14.08.2022 22:18.26.120] [LOG] Initializing new module helper …
                          [14.08.2022 22:18.26.120] [LOG] Module helper loaded: updatenotification
                          [14.08.2022 22:18.26.122] [LOG] No helper found for module: clock.
                          [14.08.2022 22:18.26.430] [LOG] Initializing new module helper …
                          [14.08.2022 22:18.26.431] [LOG] Module helper loaded: calendar
                          [14.08.2022 22:18.26.432] [LOG] No helper found for module: weather.
                          [14.08.2022 22:18.26.916] [LOG] Initializing new module helper …
                          [14.08.2022 22:18.26.917] [LOG] Module helper loaded: MMM-ImagesPhotos
                          [14.08.2022 22:18.26.918] [LOG] No helper found for module: helloworld.
                          [14.08.2022 22:18.26.919] [LOG] No helper found for module: MMM-SimpleText.
                          [14.08.2022 22:18.26.919] [LOG] All module helpers loaded.
                          [14.08.2022 22:18.27.092] [LOG] Starting server on port 8080 …
                          [14.08.2022 22:18.27.115] [LOG] Server started …
                          [14.08.2022 22:18.27.116] [LOG] Connecting socket for: updatenotification
                          [14.08.2022 22:18.27.117] [LOG] Starting module helper: updatenotification
                          [14.08.2022 22:18.27.117] [LOG] Connecting socket for: calendar
                          [14.08.2022 22:18.27.118] [LOG] Starting node helper for: calendar
                          [14.08.2022 22:18.27.118] [LOG] Connecting socket for: MMM-ImagesPhotos
                          [14.08.2022 22:18.27.119] [LOG] Starting node helper for: MMM-ImagesPhotos
                          [14.08.2022 22:18.27.119] [LOG] Sockets connected & modules started …
                          [14.08.2022 22:18.27.400] [LOG] Launching application.
                          [14.08.2022 22:18.29.770] [LOG] Create new calendarfetcher for url:
                          [14.08.2022 22:18.29.871] [INFO] Checking git for module: MMM-ImagesPhotos
                          [14.08.2022 22:18.29.965] [INFO] Checking git for module: MMM-SimpleText
                          [14.08.2022 22:18.29.985] [INFO] Checking git for module: default
                          [14.08.2022 22:18.32.381] [INFO] Calendar-Fetcher: Broadcasting 6 events.
                            @史新瑞 also u didnt show me contents of MagicMirror folder… you showed user root
                            /home/pi
                            史 2 Replies Last reply
                            • 史
                              史新瑞 @sdetweil
                              • 史
                                史新瑞 @sdetweil
                                @sdetweil Thank you, sir. Is my problem easy to solve? In addition, it’s nearly 23 o’clock here, so I will turn off my computer and use my mobile phone to receive your messages. However, in this way, I will not be able to correct it as quickly as possible according to your method
                                  sdetweil @史新瑞
                                  @史新瑞 i just installed the module…
                                  can u show me the config.js for this?
                                  the filePath parm is assuming the file is located in the same module folder…
                                  • 史
                                    史新瑞 @sdetweil
                                    @sdetweil Sorry, I can’t show it to you now, because my mother doesn’t allow me to use the computer at this time in the evening. It is already 12 o 'clock here, so I can only send it to you tomorrow morning, that is, August 15, around 9 o 'clock in Dong8 district. I am very sorry, and thank you very much for your guidance
                                      sdetweil @史新瑞
                                      @史新瑞 no problem
                                      here is my test config.js
                                       	module: 'MMM-SimpleText',
                                       	position: 'top_center',
                                      			text: {
                                      			  'value': 'Hello World!'
                                      			fontURL: {
                                      			  'value': 'Tahoma, Geneva, sans-serif'
                                      			fontSize: {
                                      			  'value': 'xx-large'
                                      			fontStyle: {
                                      			  'value': 'italic'
                                      			color: {
                                      			  'value': '#FFFFFF'
                                      			filePath: {
                                      				'value':"../../config/config.js"
                                      and a screen shot
                                      • 史
                                        史新瑞 @sdetweil
                                        @sdetweil Thank you, but my problem now is that the weather module is not working properly
