    [SOLVED] random black screen
    15 Posts 4 Posters 9.8k Views 4 Watching
    • qu1queQ
      qu1que Project Sponsor @sdetweil
      Thanks for the reply, but no docker installed in that raspbery, I’ve installed following the standard method 3 or 4 years ago, and doing the updates when they are ready. I’ve also have 2 backups of the entire micro SD. But maybe I’ll try a clean installation someday and see what happens.
      karsten13K S 2 Replies Last reply
      • karsten13K
        karsten13 @qu1que
        @qu1que
        sounds like a memory problem on your raspberry pi, may other applications are running beside mm which need much memory or some modules of mm are “eating” memory …
          sdetweil @qu1que
          @qu1que maybe increase the swap space?
            MMRIZE
            This might be not related, but why are your newsfeeds so many and frequently fetched?
            qu1queQ 1 Reply Last reply
            • qu1queQ
              qu1que Project Sponsor @MMRIZE
              @MMRIZE
              I don’t know, I have now 14 url of rss feeds, But I’ve tried with less of them and the error does not disappear.
                MMRIZE
                Usually broker_posix.cc(46) Received unexpected number of handles error might seem to happen when the memory is insufficient for various reasons. I suspect you try to open too many files(newsfeed??) at once.
                PS
                newsfeed itself might not be the reason. (14 feeds are not TOO MANY). But your other module/process would be eating memory.
                qu1queQ 2 Replies Last reply
                • qu1queQ
                  @MMRIZE
                  Maybe, I’ll try disabling some modules. Thanks. i will tell u when I try it.
                  • qu1queQ
                    @MMRIZE
                    The thing is, now that I remember, during the weekend I disabled completely newsfeed module, and the error does not disappeared. Now I’ll try disabling more modules.
                    • qu1queQ
                      qu1que Project Sponsor @qu1que
                      I’m starting to see my problem…
                      Fortunately I had saved an old config.js file with less modules than the one I have now. In studying the differences, I find this in my current config.js file:
                      Too many calls to the newsfeed module, surely that’s the reason for the error.
                      This is the configuration in the MMM-Pages module that was giving me problems
                      module: 'MMM-pages',
                                modules:
                                     [[ "calendar_monthly", "MMM-Tools", "MMM-OpenWeatherForecast", "newsfeed"],
                                     [ "calendar", "MMM-AirQuality"],
                                     [ "MMM-TelegramBot", "MMM-EyeCandy"],
                                     [ "MMM-SolarPicture", "MMM-Lunartic", "MMM-Comics"],
                                     [ "MMM-Comics" ],
                                     [ "MMM-RAIN-MAP" ],
                                     [ "MMM-RandomPhoto", "MMM-History"],
                                     [ "MMM-WeatherChart"],
                                     [ "MMM-AirQuality", "newsfeed"],
                                     [ "MMM-Wallpaper"]],
                      rotationTime: 30000,
                      fixed: ["alert", "updatenotification", "clock", "MMM-OpenmapWeather", "MMM-page-indicator"]
                        sdetweil @qu1que
                        @qu1que MagicMirror can only show or hide modules. it will load all defined in config.js, and then pages will make them show or not…
                        sone modules, not many, will sleep when hidden and restart on show. I don’t know if newsfeed is like that
                        • qu1queQ
                          It is possible that in the end the problem was with the resource-intensive MMM-RAIN-MAP module. Now it’s disabled, let’s see what happens…
                          In the end, my method is as simple as trial-and-error until it’s solved.
                            sdetweil @qu1que
                            @qu1que yrs trial and error is the key tool here
                            • qu1queQ
                              Well, I think I can tag this post with SOLVED, all day with MMM-RAIN-MAP module disabled and no more black screens.
                              Thanks all for your advice.
