    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 429.4k Views 32 Watching
      sdetweil @BKeyport
      @BKeyport I introduced a bug in 2.20.
      maximumentries includes those in the past incorrectly
      you can set it differently for each cal, but if u don’t then the module level value will be used.
      the bug is fixed in 2.21 coming oct 1.
      • BKeyportB
        @sdetweil really? I haven’t noticed. As you can see, I’ve got plenty of events…
        good to know, though.
          sdetweil @BKeyport
          @BKeyport really trouble with past events getting counted
          • H
            hogedir
            I’ve change it from 100 to 100000 and now its works,
            my calendar is showed now. thanks a lot for your reactivity guys, perfect answer.
            two other questions : this parameter symbol: ‘camera’ maybe be other value than ‘camera’? I did not understood why camera was by default… is there a list of other symbol values?
            other question : I want to extend the text limit showing because it’s looks like limited for the events that not have a eaxct duration like 10:00-12:00
            like you have here in your screen :
            Thanks.
            • BKeyportB
              BKeyport Module Developer @hogedir
              @hogedir The event you point to is generated by the IRS, and is a full day event. the text is theirs.
              Here’s my CSS, fully commented for you to borrow:
              /* CalendarExt3Agenda */
              /* Set CX3a to size, etc. */
              .CX3A {
              	font-size: 18px;
              	min-width: 440px;
              	max-width: 440px;
              	max-height: 900px;
              	overflow-y: unset;
              	text-align: left;
              	position: relative;
              	color: var(--color-text);
              	--todayColor: DarkSlateGrey;
              	--saturdayColor : orange;
              	--sundayColor: darkGoldenRod;
              /* Hide useless descriptions, you wanna know, load your calendar */
              .CX3A .event .description {
              	display: none;
              /* Hide useless locations, you wanna know, load your calendar */
              .CX3A .event .location {
              	display: none;
              /* Set up custom full day look */
              .CX3A .cellBody .fullday .event {
              	color: var(--calendarColor);
              	background-color: var(--oppositeColor);
              	max-width: 100%;
              	padding: 0px 10px;
              	width: 100%;
              /* make fullday events overflow onto next line */
              .CX3A .cellBody .fullday .event .title {
              	color: inherit;
              	overflow: unset;
              	white-space: unset;
              	text-overflow: unset;
              /* Add the icon to full day events */
              .CX3A .cellBody .fullday .event .headline {
              	display: inline-block;
              /* get rid of the icon for blanks	*/
              .CX3A .event .headline .symbol {
                display: none;
              /* fullday keep the times hidden */
              .CX3A .cellBody .fullday .event .headline .time {
              	display: none;
              /* Start Time Adjustments */
              .CX3A .event .time.startTime {
              	order: 2;
              	width: 90px;
              	text-align: right;
              /* Stretch title to left justify and organize */
              .CX3A .event .title {
              	flex-grow: 1;
              /* change date header to center & change color */
              .CX3A .agenda .cellHeader {
              	justify-content: center;
              	color: var(--text-color);
              .CX3A .agenda .cellDay {
              /* get rid of spare space & dash */
              .CX3A .event .startTime::after {
              	content: '';
              /* Adjust time space */
              .CX3A .event .time {
              	font-size: unset;
              /* Remove End time */
              .CX3A .event .endTime {
              	display: none;
              /* Adjust how tall app is */
              .CX3A .agenda {
              	position: relative;
              	max-height: 900px;
              	overflow-y: hidden;
              /* Fade adjustments */
              .CX3A .agenda::after {
              	position: absolute;
              	bottom: 0;
              	left: 0;
              	height: 6%;
              	width: 100%;
              	content: '';
              	background-image: unset;
              (shading due to developer console)
              I decided to change it up, this is what it looks like now.
              color of events is set by the calendar functionality, thusly, background is via CSS:
              	url: "http://cal.events/VReW45.ics",
              	color: "#002244",
              BKeyportB H 2 Replies Last reply Reply Quote 0
              • BKeyportB
                @MMRIZE said in MMM-CalendarExt3:
                Small news.
                Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
                Are you planning on adding this to Agenda? I could use this.
                  MMRIZE @BKeyport
                  @BKeyport already applied.
                  • H
                    hogedir @BKeyport
                    @BKeyport I don’t understand how to extend the full day event like you. mine is limited and i have some space available like that
                    I want to extend totally the text for fullday event and not having these 3 points “…”
                    BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
                    • BKeyportB
                      @hogedir It’s documented in my CSS above… Look closely you’ll find it. “fullday events overflow” is a clue.
                      • W
                        Wenike @BKeyport
                        @BKeyport I appreciate you posting your CSS, it gave me a good base to tweak to make my layout work for me (especially getting each event in the calendar’s color but still dimming when that event is in the past.
                          MMRIZE
                          Nobody like my default color settings? :(
                          BKeyportB W 2 Replies Last reply Reply Quote 0
                          • BKeyportB
                            BKeyport Module Developer @MMRIZE
                            @MMRIZE I did, when I was on a dark background. Then I decided I wanted to go with color to tell events apart, so css work it was.
                            • W
                              Wenike @MMRIZE
                              @MMRIZE I did! Except I have like 6 calendars defined and I’ve long been used to telling them apart by color on my Google calendar.
                              • luisestradaL
                                luisestrada @hogedir
                                @hogedir
                                I edited the max-width value (50% to 100%) in .CX3A .cellBody .fullday .event and solved the issue
                                • H
                                  hogedir @MMRIZE
                                  @MMRIZE how do you change the baseball icon please? which one are available to put?
                                  • BKeyportB
                                    @hogedir icons are changed at the calendar level by adding symbol: <some symbol> to each calendar in the calendar module.
                                    https://fontawesome.com/v5/search is where you can look up icons to use. The system can’t use pro icons.
                                    	symbol: "football-ball",
                                    is https://fontawesome.com/v5/icons/football-ball?s=solid&f=classic
                                    • BKeyportB BKeyport referenced this topic on
                                    • H
                                      hogedir @BKeyport
                                      @BKeyport I searched how to Hide the list of events diary and the AGENDA calendar with all the month with days because I just want to show the 3rd part of the module with all the events.
                                      like this : hiding the cross part and the other part with events :
                                        sdetweil @hogedir
                                        @hogedir please see this post
                                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1664733698317
                                        about using the developers window (ctrl-shift-i) to examine the web page and find the element u want to address
                                        this content goes into ~.MagicMirror/css/custom.css
                                        .MMM-CalendarExt3Agenda  .?????? {
                                              display:none;
                                        where ??? is the classname of the month view
                                        • BKeyportB
                                          @hogedir hiding the minical is simple: showMiniMonthCalendar: false, in your config. I suggest you read the README.md - it’s all documented.
                                          Everything other than config options is CSS - Feel free to give ideas, and @mmrize and I can help you work it out.
                                          • BKeyportB
                                            hey, @MMRIZE - I can’t figure out how to do something.
                                            One of my remotely generated events has taken to advertising in it’s title.
                                            (Washington Football vs Arizona - blah blah special event, Presented by Idiot Company)
                                            I want to get rid of everything after the dash. Not sure how to word the transform to do it - can you explain?
                                            Thanks.
                                            • 11
                                            • 12
                                            • 3 / 12
