    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 394.3k Views 32 Watching
      MMRIZE @BKeyport
      @BKeyport already applied.
      • H Offline
        hogedir @BKeyport
        @BKeyport I don’t understand how to extend the full day event like you. mine is limited and i have some space available like that
        I want to extend totally the text for fullday event and not having these 3 points “…”
        BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @hogedir
          @hogedir It’s documented in my CSS above… Look closely you’ll find it. “fullday events overflow” is a clue.
          • W Offline
            Wenike @BKeyport
            @BKeyport I appreciate you posting your CSS, it gave me a good base to tweak to make my layout work for me (especially getting each event in the calendar’s color but still dimming when that event is in the past.
              MMRIZE
              Nobody like my default color settings? :(
              BKeyportB W 2 Replies Last reply Reply Quote 0
              • BKeyportB Offline
                BKeyport Module Developer @MMRIZE
                @MMRIZE I did, when I was on a dark background. Then I decided I wanted to go with color to tell events apart, so css work it was.
                • W Offline
                  Wenike @MMRIZE
                  @MMRIZE I did! Except I have like 6 calendars defined and I’ve long been used to telling them apart by color on my Google calendar.
                  • luisestradaL Offline
                    luisestrada @hogedir
                    @hogedir
                    I edited the max-width value (50% to 100%) in .CX3A .cellBody .fullday .event and solved the issue
                    • H Offline
                      hogedir @MMRIZE
                      @MMRIZE how do you change the baseball icon please? which one are available to put?
                      • BKeyportB Offline
                        @hogedir icons are changed at the calendar level by adding symbol: <some symbol> to each calendar in the calendar module.
                        https://fontawesome.com/v5/search is where you can look up icons to use. The system can’t use pro icons.
                        	url: "http://cal.events/VReW45.ics",
                        	symbol: "football-ball",
                        is https://fontawesome.com/v5/icons/football-ball?s=solid&f=classic
                        • BKeyportB BKeyport referenced this topic on
                        • H Offline
                          hogedir @BKeyport
                          @BKeyport I searched how to Hide the list of events diary and the AGENDA calendar with all the month with days because I just want to show the 3rd part of the module with all the events.
                          like this : hiding the cross part and the other part with events :
                            sdetweil @hogedir
                            @hogedir please see this post
                            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1664733698317
                            about using the developers window (ctrl-shift-i) to examine the web page and find the element u want to address
                            this content goes into ~.MagicMirror/css/custom.css
                            .MMM-CalendarExt3Agenda  .?????? {
                                  display:none;
                            where ??? is the classname of the month view
                            • BKeyportB Offline
                              @hogedir hiding the minical is simple: showMiniMonthCalendar: false, in your config. I suggest you read the README.md - it’s all documented.
                              Everything other than config options is CSS - Feel free to give ideas, and @mmrize and I can help you work it out.
                              • BKeyportB Offline
                                hey, @MMRIZE - I can’t figure out how to do something.
                                One of my remotely generated events has taken to advertising in it’s title.
                                (Washington Football vs Arizona - blah blah special event, Presented by Idiot Company)
                                I want to get rid of everything after the dash. Not sure how to word the transform to do it - can you explain?
                                Thanks.
                                  DDE12
                                  How do I change the order of information events from
                                  ___________________________________________________________
                                  1:30 PM - 2:30 PM Event Name ________________________
                                  to
                                  Event Name ________________________1:30 PM - 2:30 PM
                                  • BKeyportB Offline
                                    BKeyport Module Developer @DDE12
                                    @DDE12 refer back to https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/24?_=1668752794543
                                    The combo of my work and @MMRIZE 's work results in that. Right around there is where I got all of my settings for my install. Feel free to experiment.
                                      cyberphox
                                      Running MagicMirror in Docker on Synology.
                                      Installed this module and it looks great on my MacBook, but when I try to visit on my mirror with Raspberry Pi 3, the module doesn’t show (just default calendar module). Get a Syntax error, unexpected token.
                                      So weird.
                                        sdetweil @cyberphox
                                        @cyberphox what version of MM are you running, and on pi, what version of OS and what browser?
                                        these modules, like many newer ones, are converting to javascript ES6 idioms that don’t work on older node versions (built into browsers as well)
                                          cyberphox @sdetweil
                                          Chromium 72.0.3626.121
                                          Raspbian Stretch
                                          MagicMirror: v2.21.0
                                            sdetweil @cyberphox
                                            @cyberphox how about node -v
                                            stretch is really old… so probably a downlevel version of javascript…
                                            • 11
                                            • 12
                                            • 3 / 12
