    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 424.6k Views 32 Watching
    • H
      hogedir @MMRIZE
      @MMRIZE how do you change the baseball icon please? which one are available to put?
      • BKeyportB
        BKeyport Module Developer @hogedir
        @hogedir icons are changed at the calendar level by adding symbol: <some symbol> to each calendar in the calendar module.
        https://fontawesome.com/v5/search is where you can look up icons to use. The system can’t use pro icons.
        	url: "http://cal.events/VReW45.ics",
        	symbol: "football-ball",
        is https://fontawesome.com/v5/icons/football-ball?s=solid&f=classic
        • BKeyportB BKeyport referenced this topic on
        • H
          hogedir @BKeyport
          @BKeyport I searched how to Hide the list of events diary and the AGENDA calendar with all the month with days because I just want to show the 3rd part of the module with all the events.
          like this : hiding the cross part and the other part with events :
            sdetweil @hogedir
            @hogedir please see this post
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1664733698317
            about using the developers window (ctrl-shift-i) to examine the web page and find the element u want to address
            this content goes into ~.MagicMirror/css/custom.css
            .MMM-CalendarExt3Agenda  .?????? {
                  display:none;
            where ??? is the classname of the month view
            • BKeyportB
              @hogedir hiding the minical is simple: showMiniMonthCalendar: false, in your config. I suggest you read the README.md - it’s all documented.
              Everything other than config options is CSS - Feel free to give ideas, and @mmrize and I can help you work it out.
              • BKeyportB
                hey, @MMRIZE - I can’t figure out how to do something.
                One of my remotely generated events has taken to advertising in it’s title.
                (Washington Football vs Arizona - blah blah special event, Presented by Idiot Company)
                I want to get rid of everything after the dash. Not sure how to word the transform to do it - can you explain?
                Thanks.
                  DDE12
                  How do I change the order of information events from
                  ___________________________________________________________
                  1:30 PM - 2:30 PM Event Name ________________________
                  to
                  Event Name ________________________1:30 PM - 2:30 PM
                  • BKeyportB
                    BKeyport Module Developer @DDE12
                    @DDE12 refer back to https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/24?_=1668752794543
                    The combo of my work and @MMRIZE 's work results in that. Right around there is where I got all of my settings for my install. Feel free to experiment.
                      cyberphox
                      Running MagicMirror in Docker on Synology.
                      Installed this module and it looks great on my MacBook, but when I try to visit on my mirror with Raspberry Pi 3, the module doesn’t show (just default calendar module). Get a Syntax error, unexpected token.
                      So weird.
                        sdetweil @cyberphox
                        @cyberphox what version of MM are you running, and on pi, what version of OS and what browser?
                        these modules, like many newer ones, are converting to javascript ES6 idioms that don’t work on older node versions (built into browsers as well)
                          cyberphox @sdetweil
                          Chromium 72.0.3626.121
                          Raspbian Stretch
                          MagicMirror: v2.21.0
                            sdetweil @cyberphox
                            @cyberphox how about node -v
                            stretch is really old… so probably a downlevel version of javascript…
                              cyberphox @sdetweil
                              No doubt…not a huge issue as it was test install…Thanks for the help!
                                sdetweil @cyberphox
                                @cyberphox said in MMM-CalendarExt3Agenda:
                                72.0.3626.121
                                chrome 72 is march 2019… so 3.5 years old
                                  cyberphox @sdetweil
                                  @sdetweil Looks like I can upgrade through terminal so might give it a go over the weekend
                                    DDE12 @BKeyport
                                    @BKeyport Thank you!
                                    I’m using both startTime and endTime and can’t get it lined up right.
                                    .CX3A .event .title {
                                      color: var(--calendarColor);
                                      order: 1;
                                      width: 120px; /* Adjust for your region width. Here I am using fixed value to make things simple */
                                      flex-grow: 1;
                                    .CX3A .event .time.startTime {
                                      order: 2;
                                      width: 52px;
                                      text-align: right;
                                    .CX3A .event .startTime::after {
                                      content: ' -';
                                    .CX3A .event .time.endTime {
                                      order: 2;
                                      width: 65px;
                                      text-align: right;
                                    .CX3A .event .symbol {
                                      order: 4;
                                    .CX3A .event .headline {
                                      justify-content: space-between;
                                    .CX3A .event .description {
                                      overflow: hidden;
                                      white-space: nowrap;
                                      text-overflow: ellipsis;
                                      max-width: 100%;
                                      font-size: 90%;
                                      color: orange;
                                      padding-left: 20px;
                                    BKeyportB D 2 Replies Last reply Reply Quote 0
                                    • BKeyportB
                                      @DDE12 I still don’t get them all lined up right - thanks to advertising in one of my schedules (Washington State Cougars @ Washington Huskies - presented by blah blah blah blah)
                                      But I’ve tweaked it enough to get it right most of the time. Just keep tweaking it.
                                        DDE12 @DDE12
                                        • BKeyportB
                                          @DDE12 wanna post back your related CSS? I’m curious about something.
                                            DDE12 @BKeyport
                                            @BKeyport
                                            I think I need to use something other than width: ##px so that it adjusts based on how much space the time takes. Is there a way to make startTime " - " endTime into a string or something and then align that to the right?
                                            .CX3A {
                                              font-size: 16px;
                                              min-width: 300px;
                                              max-width: 400px;
                                              text-align: left;
                                              color: lightgray;
                                              --saturdayColor : white;
                                              --sundayColor: white;
                                              --todayColor: gold;
                                            /* +++  Colored dot before event +++ */
                                            .CX3A .event .headline .symbol {
                                              font-size: 75%;
                                              vertical-align: text-bottom;
                                            .CX3A .event .headline .symbol.noSymbol::after {
                                              content: '|';
                                              font-weight: bold;
                                            /*  ++++ Divider Lines +++ */
                                            .CX3A .agenda .cell {
                                              padding-top: 2px;
                                              border-top: 1px solid gray;
                                              margin-top: 2px;
                                            .CX3A .cellHeaderMain {
                                              display: flex;
                                              gap: 3px;
                                              text-transform: capitalize;
                                            /* +++ Show/Hide event description or location +++ */
                                            /*.CX3A .agenda .event .description, */
                                            .CX3A .agenda .event .location {
                                              display: none;
                                            /* +++ Change order of info displayed +++ */
                                            /* to test text-wrapping */
                                            /*.CX3A {
                                              width: 300px;
                                            *.CX3A .cellBody .fullday .event {
                                              width: 100%;
                                            /* +++  Event title +++ */
                                              order: 1;
                                              flex-grow: 1;
                                              order: 2;
                                              width: 52px;
                                              text-align: right;
                                              content: ' -';
                                              order: 2;
                                              width: 65px;
                                              text-align: right;
                                              order: 3;
                                            • 11
                                            • 12
                                            • 3 / 12
