    Missing days when in portrait orientation CalendarExt3
    6 Posts 3 Posters 2.9k Views 3 Watching
    • F
      fguido
      I’m having trouble using this module. It works perfect when it’s in landscape mode, but when I turn my monitor to portrait mode using custom css, I am losing Monday and Sunday on my calendar. Any ideas?
      S M 2 Replies Last reply
        sdetweil @fguido
        @fguido said in Missing days when in portrait orientation:
        what module?
        F 1 Reply Last reply
        • F
          fguido @sdetweil
          @sdetweil oh Jeeze. I was trying to reply to the mmm-calandarext3 post.
            sdetweil @fguido
            @fguido I edited the title
              MMRIZE @fguido
              @fguido
              I need your custom.css and config.js and screenshot.
              To make things simpler, remove all other modules except original calendar and CX3, then excute MM. show me the result and the files of that moment.
                MMRIZE @fguido
                @fguido
                And I need more detail info about ‘rotating’ with custom css meaning. Because this module would use ‘vw’ things, so with ‘transform 2D’ to rotate, this will make an issue.
                Simply you can assign physical real metrics (00px) instead of relative/dynamic metrics(vw, % ) by your manual calculations. Or considering transformed result, adjust values to fit with it.
