Solved Calendar has stopped working
@sdetweil said in Calendar has stopped working:
cd ~/MagicMirror/modules/default/calendar
Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
Invalid time value
at Date.toISOString (:null:null)
at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
at Array.forEach (:null:null)
at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
at processTicksAndRejections (node:internal/process/task_queues:96:5) -
@Jonsar can u show me the cal event data in the logs right before the error?
|| tz === ‘Customized Time Zone’
I see there were two place in ical.js
and there is a timezone like this
‘Customized Time Zone 1’
so this will fail
tz === 'Customized Time Zone'
change to this
tz.startsWith('Customized Time Zone')
in all three places … 2 in node ical.j one in caldendarutils.js
@sdetweil Thank you, but I can only find 1 place in ical.js. There is one place in calendarutils.js but it is:
if(msTZName === ‘Customized Time Zone’){The whole error I get is:
[19.09.2022 21:46.41.439] [DEBUG] Search for recurring events between: Mon Sep 19 2022 21:46:41 GMT-0400 (Eastern Daylight Time) and Mon Sep 18 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
[19.09.2022 21:46.41.441] [DEBUG] Title: Tentative: XX, with dates: [null,null]
[19.09.2022 21:46.41.442] [DEBUG] event.recurrences: [object Object]
[19.09.2022 21:46.41.449] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/XXXXXXcalendar.ics RangeError: Invalid time value
@Jonsar said in Calendar has stopped working:
if(msTZName === ‘Customized Time Zone’){yes, I said above that there were actually 2… in ical.js
and to make the second look like the 1styes, in calendarutils, 1, which I gave instructions to change
if(msTZName.startsWith(‘Customized Time Zone’){
@sdetweil Sorry, I missed the second one in ical.js. It works now! Thanks so much for your help.
