Unsolved calendar with recurring event
@jasondreher ok thx will review shortly.
the day off bug has a fix in the next release ( Saturday), cal entries w BYDAY return junk
@jasondreher ok, i don’t see a problem with 2.20 or upcoming 2.21 (with the byday fix) …
do you have broadcastPastEvents:true? in the cal config?
there is a bug there, that I introduced… it chops off maxEvents incorrectly (also fixed in 2.21, Sauturday)
workaround is to increase maxEntries from 10 to 100 (or more) depending on how big the past years events are…
I do not have broadcastPastEvents: true, in my config.
I will update this weekend, add broadcastPastEvents: true, and see if that fixes anything, thanks.
@jasondreher don’t NEED broadcastPastEvents, it was just a bug I introduced… which fixed a regression of another problem…
want to run debug test…
edit config.js and add ,“DEBUG”
to the logLevel:attribute at the top of config.js
then if using pm2, pm2 stop all
then
cd ~/MagicMirror npm start >somefie.txt 2>&1
run til cal appears
ctrl-q to end
send the somefile.txt to my email (I don’t share info )
my same userid at gmailturn off debug
Wow, I cant find your email, I am sure its fairly obvious. Anyway I narrowed down the event that is not showing…
It looks all right, showing “Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)”[27.09.2022 09:25.50.700] [DEBUG] start: Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.700] [DEBUG] end:: Mon Sep 12 2022 20:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.701] [DEBUG] duration: 3600000
[27.09.2022 09:25.50.701] [DEBUG] title: TS Boot Camp
[27.09.2022 09:25.50.701] [DEBUG] Search for recurring events between: Tue Sep 27 2022 09:25:50 GMT-0500 (Central Daylight Time) and Tue Sep 26 2023 23:59:59 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.705] [DEBUG] Title: TS Boot Camp, with dates: [“2022-10-03T00:00:00.000Z”,“2022-10-10T00:00:00.000Z”]
[27.09.2022 09:25.50.705] [DEBUG] event.recurrences: undefined
[27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
[27.09.2022 09:25.50.706] [DEBUG] recurring date is Sun Oct 02 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
[27.09.2022 09:25.50.706] [DEBUG] new recurring date2 is Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.706] [DEBUG] Corrected startDate: Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.707] [DEBUG] initial tz=America/Chicago
[27.09.2022 09:25.50.707] [DEBUG] corrected tz=America/Chicago
[27.09.2022 09:25.50.707] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.707] [DEBUG] start offset=-300
[27.09.2022 09:25.50.707] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.708] [DEBUG] event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.708] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 03 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.708] [DEBUG] adjustHours=0
[27.09.2022 09:25.50.708] [DEBUG] duration: 3600000
[27.09.2022 09:25.50.708] [DEBUG] saving event: false
[27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 300
[27.09.2022 09:25.50.709] [DEBUG] recurring date is Sun Oct 09 2022 19:00:00 GMT-0500 (Central Daylight Time) offset is 5 Hour is 19
[27.09.2022 09:25.50.709] [DEBUG] new recurring date2 is Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.709] [DEBUG] Corrected startDate: Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.709] [DEBUG] initial tz=America/Chicago
[27.09.2022 09:25.50.710] [DEBUG] corrected tz=America/Chicago
[27.09.2022 09:25.50.710] [DEBUG] start date/time=Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.710] [DEBUG] start offset=-300
[27.09.2022 09:25.50.710] [DEBUG] start date/time w tz =Mon Sep 12 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.711] [DEBUG] event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.711] [DEBUG] event offset=-300 hour=19 event date=Mon Oct 10 2022 19:00:00 GMT-0500 (Central Daylight Time)
[27.09.2022 09:25.50.711] [DEBUG] adjustHours=0
[27.09.2022 09:25.50.711] [DEBUG] duration: 3600000
[27.09.2022 09:25.50.711] [DEBUG] saving event: false
[27.09.2022 09:25.50.712] [DEBUG] Processing entry…
[27.09.2022 09:25.50.712] [DEBUG] Event: -
@jasondreher and what shows on the calendar?
the 3rd should show, maybe 10th it is 2 weeks away.
I plan on updating this weekend and seeing what shows when this event comes up next, your help is greatly appreciated!!!
