Two Display
15 Posts 5 Posters 4.3k Views 5 Watching
  • K Offline
    krocaq
    Re: Rpi 4 and two monitors
    @saljoke
    Hi. Thats right. i only use 1 Pi4 to serve both displays via 2 MM instances. first the originally MagicMirror directory and the second in a MagicMirror2 directory. Both powered up via PM2 and turned off and on via PIR sensor.
    The config looks like this:
    language: “de”,
    logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”],
    timeFormat: 24,
    units: “metric”,
    electronOptions: {fullscreen:true, x:1920},
    1920 is the resolution witdh of the main display.
    Very easy to handle and good for the electrical consumption
    S 1 Reply Last reply Sep 28, 2022, 8:21 PM Reply Quote 0
      sdetweil @krocaq
      @krocaq AND you can do it with ONE directory, by using the
      environment variable
      for one instance
      MM_CONFIG_FILE=config/config.js
      for the other
      MM_CONFIG_FILE=config/config2.js
      (each on a different port, same as what u have now)
      and install all the modules in the modules folder for both,
      only those used by an instance will be loaded
      in each config you can also use different custom.css files…
      so each instance can present a different view
      L 1 Reply Last reply Oct 2, 2022, 2:47 AM Reply Quote 0
      • S sdetweil referenced this topic on Sep 28, 2022, 8:24 PM
      • L Offline
        lexcyr @sdetweil
        @sdetweil Hello,
        How to setup the environnent variable and custom css for that?
        Do you have any tutorial/guide i can use?
        S 1 Reply Last reply Oct 2, 2022, 2:58 AM Reply Quote 0
          sdetweil @lexcyr
          @lexcyr in windows u set env var with
          set varname=value
          in Linux it’s
          varname=value
          but if you are starting another program from the script, you need to do
          export varname=value
          the css name is specified in the config.js
          see the config instructions
          https://docs.magicmirror.builders/configuration/introduction.html
          L 1 Reply Last reply Oct 3, 2022, 4:16 PM Reply Quote 0
          • L Offline
            lexcyr @sdetweil
            @sdetweil Thanks for the info.
            But i think i wasn’t clear enough with my question.
            I was asking how to setup your MM, and use ONE directory and have different config for 2 display.
            From what you said it can be made by using environment variable.
            S 1 Reply Last reply Oct 3, 2022, 6:57 PM Reply Quote 0
              sdetweil @lexcyr
              @lexcyr
              create two config files
              config.js
              and
              config2.js
              this one has the left:1920 to move to the second display
              has 3 instances of calendar
              in the installers/mm.sh
              # select the 1st config file
              export MM_CONFIG_FILE=config/config.js
              # detaches the process so we can continue
              npm start &
              #select the second config file
              export MM_CONFIG_FILE=config/config2.js
              npm start
              in each config.js file you can point to different custom.css
              using the customCSS: ??? path/name
              each instance has to use a different port or course
              L 1 Reply Last reply Oct 5, 2022, 1:16 PM Reply Quote 0
              • L Offline
                lexcyr @sdetweil
                @sdetweil Thanks a lot. It works well.
                I have another question. is it possible to do the same, but only have one of the mirror config displaying on electron browser and the other one working as server to be displayed with any other browser from another device?
                like this:
                • 1st interface with config1 launch localy from electron browser with
                  -2nd interface with config2 work as server mode and launch from another device browser
                i’ve tried to just change the second section in the mm.sh file from “npm start” to “npm server”, but unfortunately it’s not working and everything just freezing.
                PS: i am running MM on Linux Lite 6.0
                S 1 Reply Last reply Oct 5, 2022, 1:18 PM Reply Quote 1
                  sdetweil @lexcyr
                  @lexcyr
                  yes but its
                  npm run server
                  not npm server
                  only the start clause
                  npm start
                  allows use without ‘run’
                  L 1 Reply Last reply Oct 6, 2022, 12:08 PM Reply Quote 0
                  • L Offline
                    lexcyr @sdetweil
                    @sdetweil thanks a lot, it works.
                      rubelahamed
                      S 1 Reply Last reply Oct 7, 2022, 5:18 PM Reply Quote 0
