    Two Display
    15 Posts 5 Posters 6.3k Views 5 Watching
    • L Offline
      lexcyr @sdetweil
      @sdetweil Thanks for the info.
      But i think i wasn’t clear enough with my question.
      I was asking how to setup your MM, and use ONE directory and have different config for 2 display.
      From what you said it can be made by using environment variable.
        sdetweil @lexcyr
        @lexcyr
        create two config files
        config.js
        and
        config2.js
        this one has the left:1920 to move to the second display
        has 3 instances of calendar
        in the installers/mm.sh
        # select the 1st config file
        export MM_CONFIG_FILE=config/config.js
        # detaches the process so we can continue
        npm start &
        #select the second config file
        export MM_CONFIG_FILE=config/config2.js
        npm start
        in each config.js file you can point to different custom.css
        using the customCSS: ??? path/name
        each instance has to use a different port or course
        • L Offline
          lexcyr @sdetweil
          @sdetweil Thanks a lot. It works well.
          I have another question. is it possible to do the same, but only have one of the mirror config displaying on electron browser and the other one working as server to be displayed with any other browser from another device?
          like this:
          • 1st interface with config1 launch localy from electron browser with
            -2nd interface with config2 work as server mode and launch from another device browser
          i’ve tried to just change the second section in the mm.sh file from “npm start” to “npm server”, but unfortunately it’s not working and everything just freezing.
          PS: i am running MM on Linux Lite 6.0
            sdetweil @lexcyr
            @lexcyr
            yes but its
            npm run server
            not npm server
            only the start clause
            npm start
            allows use without ‘run’
            • L Offline
              lexcyr @sdetweil
              @sdetweil thanks a lot, it works.
                rubelahamed
                How to setup the environnent variable and custom css for that?
                Do you have any tutorial/guide i can use?
                  sdetweil @rubelahamed
                  @rubelahamed see this post
                  https://forum.magicmirror.builders/topic/17239/two-display/5?_=1665163023943
                  customCss is a config Parm in config.js
                  see
                  https://docs.magicmirror.builders/configuration/introduction.html
                    MarkV
                    Maybe a noobish question but why isn’t possible to run magicmirror and display it over 2 screens.
                    So that you can say like module x on display 1 and module y on display 2 for example through a JS class??
                      sdetweil @MarkV
                      @MarkV well you ‘can’, but you have to do it manually, drag the mm window over both screens. but maximize will only do one screen. same on windows.
                      where the module is displayed depends on the css structure. the ‘position’ is a predefined area in main.css, the module returns a blob of content (html div) and the mm runtime injects the content into its configured location
                        MarkV @sdetweil
                        Oh oke. But on windows you can also expand the desktop en have some things start on one en other thongs on the second screen…
                        To bad that you have to drag them this would be one of the best addons for MMM
