    "MMM-RTSPStream" is not starting after update
    3 Posts 3 Posters 443 Views 3 Watching
      JVF2
      A question from a layman:
      I have updated the module “MMM-RTSPStream” today.
      Unfortunately the module does not start anymore even with factory settings in the “config.js”.
      How can I install the previous version?
      Thanks in advance.
      • JerryPJ Offline
        JerryP
        After update i’ts running fine her.
        I only whit git pull and not nom install.
        I make a backup of the old MMM-rspt map
        so I can sent you a copy
        • BKeyportB Online
          BKeyport Module Developer @JVF2
          @JVF2
          First things first, re-run npm install in the module directory. Looks like author may have changed out some dependencies.
          If that don’t fix it, please check the magic mirror logs for errors. (if you use PM2, run pm2 logs in a second terminal instance, and restart magic mirror, you’ll be able to see if something’s missing)
          It may also be that the module is just breaking… I can’t get it to work at all, for instance.
