    Replacement for MMM button due to Node-Abi error.
    5 Posts 2 Posters 941 Views 2 Watching
      robiv8
      Hello to all,
      since MMM-Button has not been maintained and updated for 5-6 years, the Node-Abi problem has not been solved and the workarounds do not work, is there an alternative?
      Robert
        sdetweil @robiv8
        @robiv8 use my fork
        https://github.com/sdetweil/MMM-Buttons
        problem is the electron-rebuild was installed in the module folder
        instead of the MM folder… so it couldn’t find the electron info
        i fixed the package,json, and a made an external postinstall script
        to install eb in the mm folder if not present and then npm install works
        R 1 Reply Last reply
          robiv8 @sdetweil
          Hallo,
          Here the same error:
          pi@InfoTerminal:~/MagicMirror/modules $ git clone https://github.com/Jopyth/MMM-Buttons.git
          Klone nach 'MMM-Buttons' ...
          remote: Enumerating objects: 54, done.
          remote: Total 54 (delta 0), reused 0 (delta 0), pack-reused 54
          Entpacke Objekte: 100% (54/54), Fertig.
          pi@InfoTerminal:~/MagicMirror/modules $ cd MMM-Buttons/
          pi@InfoTerminal:~/MagicMirror/modules/MMM-Buttons $ npm install
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          > Magic-Mirror-Module-Buttons@1.0.0 postinstall
          > node_modules/.bin/electron-rebuild -e ../../node_modules/electron
          ⠋ Searching dependency tree
          An unhandled error occurred inside electron-rebuild
          Could not detect abi for version 19.1.3 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
          Error: Could not detect abi for version 19.1.3 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
              at Object.getAbi (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/node-abi/index.js:36:9)
              at new Rebuilder (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/src/rebuild.js:126:48)
              at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/src/rebuild.js:404:23)
              at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/src/rebuild.js:427:16)
              at /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/src/cli.js:124:33
              at Generator.next (<anonymous>)
              at fulfilled (/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/electron-rebuild/lib/src/cli.js:6:58)
          npm ERR! code 255
          npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons
          npm ERR! command failed
          npm ERR! command sh /tmp/postinstall-6787d5d5.sh
          npm ERR!     /home/pi/.npm/_logs/2022-10-16T20_33_40_733Z-debug-0.log
            sdetweil @robiv8
            @robiv8 yes, the original is broken, use my fork
              robiv8 @sdetweil
              Ups, sorry for the mistake! sdetweil instead of jopyth :-)
              And … Great work. Thank you.
              pi@InfoTerminal:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
              Klone nach ‘MMM-Buttons’ …
              remote: Enumerating objects: 56, done.
              remote: Counting objects: 100% (4/4), done.
              remote: Compressing objects: 100% (4/4), done.
              remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
              Entpacke Objekte: 100% (56/56), Fertig.
              ./postinstall
              ⠴ Building module: epoll, Completed: 0make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
              CXX(target) Release/obj.target/epoll/src/epoll.o
              ⠋ Building module: epoll, Completed: 0 SOLINK_MODULE(target) Release/obj.target/epoll.node
              ⠼ Building module: epoll, Completed: 0 COPY Release/epoll.node
              make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
              ✔ Rebuild Complete
              added 6 packages, and audited 7 packages in 5m
              found 0 vulnerabilities
