    MM will not start
    32 Posts 3 Posters 9.0k Views 3 Watching
      bworch @sdetweil
      @sdetweil once I delete the mm instance; can I rename the MagicMirror instance to mm. thanks
        sdetweil @bworch
        @bworch i do not know
        but you could edit the installers/pm2_MagicMirror.json
        (this is how I give the pretty name, not the script name)
        file and change the name to mm (check the paths as well)
          "apps" : [{
            "name"        : "MagicMirror",
            "script"      : "/home/pi/MagicMirror/installers/mm.sh",
            "watch"       : ["/home/pi/MagicMirror/config/config.js"]
        and then do (delete old, add new)
        pm2 delete MagicMirror
        pm2 save
        pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
        pm2 save
          bworch @sdetweil
          @sdetweil thanks for all your help.
            bworch
            I followed your instructions, and it still will not start. I also restart the pi. this is what I have now.
            thanks
              bworch
              I did a pm2 show and this is what I got.
              thanks
                bworch @sdetweil
                @sdetweil followed your instructions, still will not start. I have this now.
                did a pm2 show
                  sdetweil @bworch
                  @bworch do
                  pm2 logs --lines=100
                  may be better without pm2 for debug
                  pm2 stop all
                  npm start >somefile.txt 2>&1
                  wait 15 seconds
                  ctrl-c
                  edit the somefile.txt
                    bworch @sdetweil
                    @sdetweil couldn’t get the txt file to show. how would I edit it.
                      sdetweil @bworch
                      @bworch nano somefile.txt
                      or whatever text editor you like
                        bworch @sdetweil
                          sdetweil @bworch
                          @bworch fun times…
                          npm install electron@19.0.15
                            bworch @sdetweil
                            I thank you for sticking with me.
                              sdetweil @bworch
                              @bworch ok, I suggest you run my upgrade script
                              see https://github.com/sdetweil/MagicMirror_scripts
                              the upgrade script second pass with
                              force
                              instead of apply
                                bworch @sdetweil
                                @sdetweil which line
                                  bworch @sdetweil
                                  @sdetweil I accidently ran it as is, I then couldn’t find where to make the change. Sorry
                                    sdetweil @bworch
                                    @bworch
                                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                                      bworch @sdetweil
                                      @sdetweil My VNC terminal when Black, is that normal.
                                        sdetweil @bworch
                                        @bworch when? whouldn’t go black
                                        i use SSH never VNC…
                                          bworch @sdetweil
                                          @sdetweil that command you gave me did a lot of stuff then went black, should I force a restart on the pi.
                                            sdetweil @bworch
                                            @bworch it just ends and says upgrade completed
                                            I ‘guess’
