    MM will not start
    32 Posts 3 Posters 8.8k Views 3 Watching
      bworch
      I did a pm2 show and this is what I got.
      thanks
        bworch @sdetweil
        @sdetweil followed your instructions, still will not start. I have this now.
        did a pm2 show
          sdetweil @bworch
          @bworch do
          pm2 logs --lines=100
          may be better without pm2 for debug
          pm2 stop all
          npm start >somefile.txt 2>&1
          wait 15 seconds
          ctrl-c
          edit the somefile.txt
            bworch @sdetweil
            @sdetweil couldn’t get the txt file to show. how would I edit it.
              sdetweil @bworch
              @bworch nano somefile.txt
              or whatever text editor you like
                bworch @sdetweil
                  sdetweil @bworch
                  @bworch fun times…
                  npm install electron@19.0.15
                    bworch @sdetweil
                    I thank you for sticking with me.
                      sdetweil @bworch
                      @bworch ok, I suggest you run my upgrade script
                      see https://github.com/sdetweil/MagicMirror_scripts
                      the upgrade script second pass with
                      force
                      instead of apply
                        bworch @sdetweil
                        @sdetweil which line
                          bworch @sdetweil
                          @sdetweil I accidently ran it as is, I then couldn’t find where to make the change. Sorry
                            sdetweil @bworch
                            @bworch
                            bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                              bworch @sdetweil
                              @sdetweil My VNC terminal when Black, is that normal.
                                sdetweil @bworch
                                @bworch when? whouldn’t go black
                                i use SSH never VNC…
                                  bworch @sdetweil
                                  @sdetweil that command you gave me did a lot of stuff then went black, should I force a restart on the pi.
                                    sdetweil @bworch
                                    @bworch it just ends and says upgrade completed
                                    I ‘guess’
                                      bworch @sdetweil
                                      @sdetweil I did a force restart on the pi, and it is working on the screen, but VNC terminal isn’t picking it up, it just shows the pi splash screen. at least the display is working. Not sure why it isn’t showing on the VNC terminal.
                                        bworch @sdetweil
                                        @sdetweil I guess it isn’t working I am getting a bunch of lines like this
                                        If you have any other ideas, let me know. I need to stop now. thanks very much.
                                        S B 2 Replies Last reply Reply Quote 0
                                          sdetweil @bworch
                                          @bworch that is a pm2 error, needs to me updated
                                          see pm2 --help
                                          for update
                                            bworch @bworch
                                            @bworch so I go another sm card build it again. I copied my config, modules, and CSS files over, and when I run an npm start MagicMorror I get the following. I guess we don’t use pm2 anymore. I get a black screen if it starts. I am also getting a commit or stash again. How do I commit or stash.
                                            magicmirror@2.21.0 start
                                            [15.10.2022 15:26.51.630] [LOG] Starting MagicMirror: v2.21.0
                                            [15.10.2022 15:26.51.646] [LOG] Loading config …
                                            [15.10.2022 15:26.51.664] [LOG] Loading module helpers …
                                            [15.10.2022 15:26.51.671] [LOG] No helper found for module: alert.
                                            [15.10.2022 15:26.51.730] [LOG] Initializing new module helper …
                                            [15.10.2022 15:26.51.734] [LOG] Module helper loaded: updatenotification
                                            [15.10.2022 15:26.51.739] [LOG] No helper found for module: clock.
                                            [15.10.2022 15:26.51.743] [LOG] No helper found for module: currentweather.
                                            [15.10.2022 15:26.51.749] [LOG] No helper found for module: weatherforecast.
                                            [15.10.2022 15:26.52.581] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘async’
                                            Require stack:
                                            • /home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js
                                            • /home/bworch/MagicMirror/js/app.js
                                            • /home/bworch/MagicMirror/js/electron.js
                                            • /home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                            [15.10.2022 15:26.52.605] [LOG] Loading module helpers …
                                            [15.10.2022 15:26.52.609] [LOG] No helper found for module: alert.
                                            [15.10.2022 15:26.52.612] [LOG] Initializing new module helper …
                                            [15.10.2022 15:26.52.616] [LOG] Module helper loaded: updatenotification
                                            [15.10.2022 15:26.52.619] [LOG] No helper found for module: clock.
                                            [15.10.2022 15:26.52.621] [LOG] No helper found for module: currentweather.
                                            [15.10.2022 15:26.52.624] [LOG] No helper found for module: weatherforecast.
                                            [15.10.2022 15:26.52.629] [ERROR] App threw an error during load
                                            [15.10.2022 15:26.52.634] [ERROR] Error: Cannot find module ‘async’
                                            Require stack:
                                            • at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                                              at n._resolveFilename (node:electron/js2c/browser_init:245:1105)
                                              at Module._resolveFilename (/home/bworch/MagicMirror/node_modules/module-alias/index.js:49:29)
                                              at Module._load (node:internal/modules/cjs/loader:785:27)
                                              at c._load (node:electron/js2c/asar_bundle:5:13343)
                                              at Module.require (node:internal/modules/cjs/loader:1012:19)
                                              at require (node:internal/modules/cjs/helpers:102:18)
                                              at Object. (/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js:3:13)
                                              at Module._compile (node:internal/modules/cjs/loader:1118:14)
                                              at Module._extensions…js (node:internal/modules/cjs/loader:1173:10)
                                              [15.10.2022 15:26.52.639] [ERROR] Whoops! There was an uncaught exception…
                                              [15.10.2022 15:26.52.663] [ERROR] Error: Cannot find module ‘async’
                                              Require stack:
                                              at Module._extensions…js (node:internal/modules/cjs/loader:1173:10) {
                                              code: ‘MODULE_NOT_FOUND’,
                                              requireStack: [
                                              ‘/home/bworch/MagicMirror/modules/MMM-Stock/node_helper.js’,
                                              ‘/home/bworch/MagicMirror/js/app.js’,
                                              ‘/home/bworch/MagicMirror/js/electron.js’,
                                              ‘/home/bworch/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                                              undefined
                                              [15.10.2022 15:26.52.673] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                              [15.10.2022 15:26.52.674] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                              [15.10.2022 15:26.53.407] [LOG] Launching application.
                                              [2177:1015/152654.435494:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                              [2204:1015/152654.735310:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                              [15.10.2022 15:27.30.480] [LOG] Shutting down server…
                                              [15.10.2022 15:27.30.487] [LOG] Stopping module helper: updatenotification
                                              [15.10.2022 15:27.30.490] [LOG] Stopping module helper: updatenotification
                                              [15.10.2022 15:27.30.492] [ERROR] Whoops! There was an uncaught exception…
                                              [15.10.2022 15:27.30.496] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
                                              at App.stop (/home/bworch/MagicMirror/js/app.js:257:14)
                                              at App. (/home/bworch/MagicMirror/js/electron.js:145:7)
                                              at App.emit (node:events:526:28)
                                              at appMethod (node:electron/js2c/browser_init:69:1830)
                                              at Object.execute (node:electron/js2c/browser_init:69:5966)
                                              at MenuItem.click (node:electron/js2c/browser_init:73:1862)
                                              at a._executeCommand (node:electron/js2c/browser_init:81:2453)
                                              [15.10.2022 15:27.30.499] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                              [15.10.2022 15:27.30.501] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                              bworch@raspberrypi:~/MagicMirror $
                                            not sure what to do. may have a bad config file. thanks
