    Multiple screens fo MM.
    36 Posts 13 Posters 30.1k Views 15 Watching
    • kayakbabeK
      kayakbabe @hogedir
      @hogedir With a raspberry 4 you can have two displays. I’m thinking they can be set up as an extended desktop . Then it’s no big deal with the default magic mirror.
      Top_left and top_right would end up being left and right…
      I haven’t tried this with MM. But I have used my pi with two screens. But in my mind it ought to work with MM.
      Just don’t use the middle_center or any position that would span across both monitors.
      • H
        hogedir @kayakbabe
        @kayakbabe I think we need two electron display, so it’s not quite easy. it’s not just top_left and top_right. I need 2 MMM, 1 magic mirror per screen.
          sdetweil @hogedir
          @hogedir electron (and other browsers) runs maximized, which is only one screen…
          you can DRAG the edge to make the window larger, but cannot maximize over two screens…
          you can run separate instances of MM on each display…
          • BKeyportB
            BKeyport Module Developer @hogedir
            @hogedir I had two running off one display, just two different Magicmirror installs. I forgot how it works though, was using them as a temporary menu display.
            Something about calling different config files if I recall right.
            S K 2 Replies Last reply Reply Quote 0
              sdetweil @BKeyport
              @BKeyport MM_CONFIG environment variable
              allows the different configs off the same directory tree
              • K
                karam @BKeyport
                @BKeyport this answer inspired me to test it, so I have a solution:
                1. create two different folders.
                2. configure each install as you like.
                3. edit each electron file in each folder “js/electron.js”
                4. change the default resolution and position based on your screens.
                  here is my config:
                let electronOptionsDefaults = {
                                width: 1280,
                                height: 1024,
                                x: 1366,
                                y: 0,
                NOTE: there are many better methods (electron-multi-monitor for example) but this is the easiest that I could find
                  sdetweil @karam
                  @karam u can set the electronOptions in config.js, you don’t need to edit the source file
                  then you can do it with one folder,
                  and two config files
                  MM_CONFIG=config1.js
                  for one
                  and
                  MM_CONFIG=config2.js
                  for the other
                  all modules for both are installed in modules folder, only ones referenced in config file are used
                  installers/mm.sh is the script used by my pm2 setup routine
                  copy that to mm2.sh
                  and then add the export MM_CONFIG=
                  to each
                  then copy the pm2_magicmirror.json
                  and change the title and the mm.sh filename
                  then pm2 start installers/??? (whatever name u copied the json file to for the second mm)
                  pm2 save
                  then on reboot you will get both
                  C S 2 Replies Last reply Reply Quote 1
                    cburchett @sdetweil
                    @sdetweil: can you please share an example? I am not sure how to indicate the secondary display in the config files. Thank you!
                      sdetweil @cburchett
                      @cburchett it’s one big display, so you have to tell it how far from the left edge to start this display.
                      see
                      https://forum.magicmirror.builders/topic/6623/multiple-screens-fo-mm/18?_=1666468889775
                      only need x for horizontal monitors
                      or y for vertical
                        cburchett @sdetweil
                        @sdetweil Perfect! Thank you.
                          Sagar73594 @sdetweil
                          @sdetweil said in Multiple screens fo MM.:
                          Can you please elaborate, a little bit more? I’m trying this, but not understood well.
                          Thank You.
                            sdetweil @Sagar73594
                            @Sagar73594 if you have a bash or sh script, you can set environment variables that the MM code will read
                            export MM_CONFIG=??? filename
                            will cause filename to be used as the name of the file to read for configuration (replacing config.js)
                            if you use my install script and selected use pm2, then the script is
                            ~/MagicMirror/installers/mm.sh
                            before the line
                            npm start
                            add the line above to set the file name
                            so, by using different config files, one could launch multiple instances of MagicMirror from the same set of files.
                            some could target one display and others another, and some could be server only as weill.
                            one could also install 50 modules and use the same 25 in all instances and some mix of the others in different instances, all from the same set of files in the MagicMirror folder tree.
                            C 2 Replies Last reply Reply Quote 0
                              chichi1887 @sdetweil
                              before the line
                              npm start
                                before the line
                                npm start
                                Hi Sagar,
                                Hello Sagar, thank you for your guidance. Unfortunately, I keep encountering an error upon startup. A version starts automatically with the familiar error message “npm run config: check”. I stop the MagicMirror and manually start it from the MagicMirror folder with npm start, but then it allegedly cannot find the config. As you described, I created config1 and config2, then edited installers/mm.sh and mm2.sh. It looks something like this now:
                                export MM_CONFIG=config2.js
                                DISPLAY=:2 npm start
                                I also copied the pm2_MagicMirros.json once and simply appended a “1” to the name. The configuration looks like this:
                                “apps” : [{
                                “name” : “MagicMirror”,
                                “script” : “/home/pi/MagicMirror/installers/mm.sh”,
                                “watch” : [“/home/pi/MagicMirror/config/config1.js”]
                                Do you perhaps have any tips for me on what I might be doing wrong?
                                  sdetweil @chichi1887
                                  @chichi1887 well, you need two pm2_MagcMirror.json, right? and each points to a different mm.sh, right?
                                  original
                                  pm2_MagicMirror.json
                                  "apps" : [{
                                  "name" : "MM_Screen1",
                                  "script" : "/home/pi/MagicMirror/installers/mm.sh",
                                  "watch" : ["/home/pi/MagicMirror/config/config.js"]
                                  new pm2_MagicMirror2.json
                                  "apps" : [{
                                  "name" : "MM_Screen2",
                                  "script" : "/home/pi/MagicMirror/installers/mm2.sh",
                                  "watch" : ["/home/pi/MagicMirror/config/config2.js"]
                                  then
                                  pm2 start each json
                                  and then pm2 save
                                  to test before pm2 start , you can
                                  installers/mm2.sh
                                  or
                                  installers/mm.sh
                                  to start them both, open another terminal window or ssh session, starting one in each
                                  ctrl-c in the term window will end that instance
                                    installers/mm2.sh
                                    Hey,
                                    the mm.sh starts without a problem but the second has this
                                    all modules that starts on the mm.sh are disable in the mm2 config.
                                    Display=0 in both are correkt or the second must be nr.1?
                                      chichi1887 @chichi1887
                                      When I start the mm2.sh script, despite the correct configuration, it takes the config.js instead of the config2.js. Therefore, it seems unable to start both instances simultaneously because it attempts to open the same config.js. The configuration looks like this in the mm2.sh script:
                                      DISPLAY=:0 npm start
                                      the pm2_MagicMirror2.json is copy and paste from u ;-)
                                        @chichi1887 see this from the doc
                                          thx so much, both starts, only problem both start at the same Screen and i can’t change the position or start screen. Must change the Display from 0 to 1 oder in the mm.sh config?
                                            @chichi1887 yes , Linux treats the two monitors as one big display, so you have to add
                                            electronOptions:{ left:xxxx}
                                            above the modules:[] list
                                            to one of the config.js to move the second mm over one screen width size
                                            if vertical, then it’s y:xxxx
                                            BKeyportB C 2 Replies Last reply Reply Quote 0
