    CORS policy
    20 Posts 3 Posters 7.2k Views 3 Watching
      bicolorbore586 @sdetweil
      I’ve tried to do that, now get pretty much the same result, but with a slightly different bit at the end.
      Access to fetch at ‘https://api.weatherbit.io/v2.0/forecast/daily?lat=xxx&lon=-xxx&units=M&key=a…’ from origin ‘http://localhost:8080’ has been blocked by CORS policy: The ‘Access-Control-Allow-Origin’ header contains multiple values ‘*, *’, but only one is allowed. Have the server send the header with a valid value, or, if an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
      api.weatherbit.io/v2…:1
      Failed to load resource: net::ERR_FAILED
      weatherbit.js:66 Could not load data … TypeError: Failed to fetch
      at Class.fetchData (weatherprovider.js:136:27)
      at Class.fetchWeatherForecast (weatherbit.js:53:8)
      at weather.js:184:27
      weather.js:150 New weather information available.
      localhost/:1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
        sdetweil @bicolorbore586
        @bicolorbore586 did u git pull, npm install after switch
          @sdetweil yes, followed your instructions to the letter
            @bicolorbore586 custom.css is because it doesn’t exist by default. if u used my install script I create it for you
            touch ~/MagicMirror/css/custom.css
              @sdetweil I used the MagicMirror installation instructions (assuming manual install) to install the software.
              Have just tried your git fetch origin
              But get fatal: Refusing to fetch into current branch refs/heads/develop of none-bare repository.
              (Sorry, you’re probably shaking your head, but I am a complete noob at all this)
                @bicolorbore586 there were two choices
                manual install
                git checkout develop
                git pull
                npm install
                or the other
                • karsten13K Offline
                  karsten13 @sdetweil
                  I think the cors proxy is not new in the weather module (but in newsfeed) so last release should work.
                  The cors proxy was not enabled for all weather providers, only for envcanada and darksky, so it must be enabled in the config for weatherbit by adding useCorsProxy: true, to the weather config.
                    sdetweil @karsten13
                    @karsten13 ah, I thought we went proxy everywhere
                      karsten13 @sdetweil
                      had to look in the code again … but may we should set default true for all providers …
                        sdetweil @karsten13
                        @karsten13 getting that way
                        localhost is usually allowed 0.0.0.0 ( I consider to be a bug to send this anywhere) is not
                          @sdetweil @karsten13 have added in the useCorsProxy: true
                          Have since updated MagicMirror, now getting
                          Could not load data … TypeError: Cannot read properties of undefined (reading ‘0’)
                          which when clicked on shows weatherbit.js
                          code_text
                          ```/* global WeatherProvider, WeatherObject */
                          /* MagicMirror²
                           * Module: Weather
                           * Provider: Weatherbit
                           * By Andrew Pometti
                           * MIT Licensed
                           * This class is a provider for Weatherbit, based on Nicholas Hubbard's class
                           * for Dark Sky & Vince Peri's class for Weather.gov.
                          WeatherProvider.register("weatherbit", {
                          	// Set the name of the provider.
                          	// Not strictly required, but helps for debugging.
                          	providerName: "Weatherbit",
                          	// Set the default config properties that is specific to this provider
                          	defaults: {
                          		apiBase: "https://api.weatherbit.io/v2.0",
                          		apiKey: "",
                          		lat: 0,
                          		lon: 0
                          	fetchedLocation: function () {
                          		return this.fetchedLocationName || "";
                          	fetchCurrentWeather() {
                          		this.fetchData(this.getUrl())
                          			.then((data) => {
                          				if (!data || !data.data[0] || typeof data.data[0].temp === "undefined") {
                          					// No usable data?
                          					return;```
                          Forgive me, again for being a noob, but I didn’t think this required any information in, however having substituted the lat and lon zero’s for my location, still throws up the same and error and points me to the [0] following !data.data
                            @bicolorbore586 never edit our code, all config goes in config.js
                            u need lat and long (how else does it know where u are)
                            all numbers and true/false have no quotes
                            anything with a letter or special character does need quotes
                            u need weatherProvider
                            apikey
                            lat
                            lon
                            and type (forecast or current)
                            and
                            useCorsProxy: true
                              ok, have put it back to how it was… that was final “can I get this to work, before I ask for further help”
                              this is my config.js
                              code_text
                              			module: "weather",
                              				weatherProvider: "weatherbit",
                              				type: "current",
                              				lat: 5,
                              				lon: -1,
                              				apiKey: "ab4",
                              				useCorsProxy: true
                              			module: "weather",
                              			header: "Weather Forecast",
                              				type: "forecast",
                              				lat: 5,
                              				lon: -1,
                              				initialLoadDelay: 1,
                              				apiKey: "ab4",
                              				useCorsProxy: true
                                @bicolorbore586 ok, lousy provider error reporting…
                                i want you to edit the provider weatherbit.js and
                                using your config (with the bad apikey) I get the ‘0’ error too
                                change this (starting on line 38)
                                						// No usable data?
                                						return;
                                					const currentWeather = this.generateWeatherDayFromCurrentWeather(data);
                                					this.setCurrentWeather(currentWeather);
                                to this
                                				if(!data || (data && data.error)){
                                					Log.error("Could not load data ... ", data?data.error: "no data returned");
                                				else {
                                						// No usable data?
                                						return;
                                then save and
                                restart mm, open the developers window
                                ctrl-shift-i
                                select the console tab
                                and enter weath
                                in the filter field
                                there should be a red line of text , with the weatherbit.js name to the right
                                  so I commented out the original text and added in the new:
                                  code_text
                                  ``` fetchCurrentWeather() {
                                  			.then((data) => {
                                  				/*if (!data || !data.data[0] || typeof data.data[0].temp === "undefined") {
                                  					// No usable data?
                                  					return;
                                  				this.setCurrentWeather(currentWeather);*/
                                  				else {
                                  						// No usable data?
                                  						return;
                                  			.catch(function (request) {
                                  				Log.error("Could not load data ... ", request);
                                  			.finally(() => this.updateAvailable());
                                    bicolorbore586 @bicolorbore586
                                    @bicolorbore586 from the line Could not load data … TypeError: Cannot read properties of undefined (reading ‘0’) at weatherbit.is
                                      @bicolorbore586 can u email me your apikey
                                      same userid as on this post
                                      at gmail
                                      or send me a direct message
                                      the returned data is not coming back in the expected format
                                        @bicolorbore586 thanks for the key
                                        the error is
                                        Your request count (159) is over the allowed limit of 50 per day - Upgrade your key, or retry after 670.2 minutes
                                        and u have 2 modules configured, so each will fetch separately, so u have to change the update cycle to once/hour
                                        in both modules, (default 10 mins)
                                        updateInterval: 60 * 60 * 1000
                                        and every MM restart sends 2 requests, 1 for each module
                                        change the new code to look like this…
                                        				if(!data || (data && data.error) || data.status_message){
                                        					Log.error("Could not load data ... ", data?(data.error|| data.status_message): "no data returned");
                                        				else {
                                        						// No usable data?
                                        						return;
                                        crappy api implementation… should set error for all errors, not
                                        put error info in good data returns
