    CORS policy
    20 Posts 3 Posters 7.2k Views 3 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      I think the cors proxy is not new in the weather module (but in newsfeed) so last release should work.
      The cors proxy was not enabled for all weather providers, only for envcanada and darksky, so it must be enabled in the config for weatherbit by adding useCorsProxy: true, to the weather config.
        sdetweil @karsten13
        @karsten13 ah, I thought we went proxy everywhere
          karsten13 @sdetweil
          had to look in the code again … but may we should set default true for all providers …
            sdetweil @karsten13
            @karsten13 getting that way
            localhost is usually allowed 0.0.0.0 ( I consider to be a bug to send this anywhere) is not
              bicolorbore586 @sdetweil
              @sdetweil @karsten13 have added in the useCorsProxy: true
              Have since updated MagicMirror, now getting
              Could not load data … TypeError: Cannot read properties of undefined (reading ‘0’)
              which when clicked on shows weatherbit.js
              code_text
              ```/* global WeatherProvider, WeatherObject */
              /* MagicMirror²
               * Module: Weather
               * Provider: Weatherbit
               * By Andrew Pometti
               * MIT Licensed
               * This class is a provider for Weatherbit, based on Nicholas Hubbard's class
               * for Dark Sky & Vince Peri's class for Weather.gov.
              WeatherProvider.register("weatherbit", {
              	// Set the name of the provider.
              	// Not strictly required, but helps for debugging.
              	providerName: "Weatherbit",
              	// Set the default config properties that is specific to this provider
              	defaults: {
              		apiBase: "https://api.weatherbit.io/v2.0",
              		apiKey: "",
              		lat: 0,
              		lon: 0
              	fetchedLocation: function () {
              		return this.fetchedLocationName || "";
              	fetchCurrentWeather() {
              		this.fetchData(this.getUrl())
              			.then((data) => {
              				if (!data || !data.data[0] || typeof data.data[0].temp === "undefined") {
              					// No usable data?
              					return;```
              Forgive me, again for being a noob, but I didn’t think this required any information in, however having substituted the lat and lon zero’s for my location, still throws up the same and error and points me to the [0] following !data.data
                sdetweil @bicolorbore586
                @bicolorbore586 never edit our code, all config goes in config.js
                u need lat and long (how else does it know where u are)
                all numbers and true/false have no quotes
                anything with a letter or special character does need quotes
                u need weatherProvider
                apikey
                lat
                lon
                and type (forecast or current)
                and
                useCorsProxy: true
                  ok, have put it back to how it was… that was final “can I get this to work, before I ask for further help”
                  this is my config.js
                  code_text
                  			module: "weather",
                  				weatherProvider: "weatherbit",
                  				type: "current",
                  				lat: 5,
                  				lon: -1,
                  				apiKey: "ab4",
                  				useCorsProxy: true
                  			module: "weather",
                  			header: "Weather Forecast",
                  				type: "forecast",
                  				lat: 5,
                  				lon: -1,
                  				initialLoadDelay: 1,
                  				apiKey: "ab4",
                  				useCorsProxy: true
                    @bicolorbore586 ok, lousy provider error reporting…
                    i want you to edit the provider weatherbit.js and
                    using your config (with the bad apikey) I get the ‘0’ error too
                    change this (starting on line 38)
                    						// No usable data?
                    						return;
                    					const currentWeather = this.generateWeatherDayFromCurrentWeather(data);
                    					this.setCurrentWeather(currentWeather);
                    to this
                    				if(!data || (data && data.error)){
                    					Log.error("Could not load data ... ", data?data.error: "no data returned");
                    				else {
                    						// No usable data?
                    						return;
                    then save and
                    restart mm, open the developers window
                    ctrl-shift-i
                    select the console tab
                    and enter weath
                    in the filter field
                    there should be a red line of text , with the weatherbit.js name to the right
                      so I commented out the original text and added in the new:
                      code_text
                      ``` fetchCurrentWeather() {
                      			.then((data) => {
                      				/*if (!data || !data.data[0] || typeof data.data[0].temp === "undefined") {
                      					// No usable data?
                      					return;
                      				this.setCurrentWeather(currentWeather);*/
                      				else {
                      						// No usable data?
                      						return;
                      			.catch(function (request) {
                      				Log.error("Could not load data ... ", request);
                      			.finally(() => this.updateAvailable());
                        bicolorbore586 @bicolorbore586
                        @bicolorbore586 from the line Could not load data … TypeError: Cannot read properties of undefined (reading ‘0’) at weatherbit.is
                          @bicolorbore586 can u email me your apikey
                          same userid as on this post
                          at gmail
                          or send me a direct message
                          the returned data is not coming back in the expected format
                            @bicolorbore586 thanks for the key
                            the error is
                            Your request count (159) is over the allowed limit of 50 per day - Upgrade your key, or retry after 670.2 minutes
                            and u have 2 modules configured, so each will fetch separately, so u have to change the update cycle to once/hour
                            in both modules, (default 10 mins)
                            updateInterval: 60 * 60 * 1000
                            and every MM restart sends 2 requests, 1 for each module
                            change the new code to look like this…
                            				if(!data || (data && data.error) || data.status_message){
                            					Log.error("Could not load data ... ", data?(data.error|| data.status_message): "no data returned");
                            				else {
                            						// No usable data?
                            						return;
                            crappy api implementation… should set error for all errors, not
                            put error info in good data returns
