    Online Radio
    52 Posts 4 Posters 29.4k Views 4 Watching
    • T Offline
      tanvir586 @wishmaster270
      @wishmaster270 Just updated. Think I’m doing it right. First I’ve installed the streamlink. And then I went to the MMM-MplayerRadio folder and execute git pull.
      I was bit confused about the streamlink. Didn’t understand where to install it , on the MMM-MplayerRadio folder or just normal installation. Finally I installed normally. Hope I’m doing it right.
      • wishmaster270W Offline
        wishmaster270 Module Developer @tanvir586
        @tanvir586
        Normal installation is the right thing. If you got sound with the new configuration everything is fine.
        Hope the disconnect will be recognized correctly and your stream restarts now.
        • T Offline
          @wishmaster270 I’m not getting any sound.
          config is right?
          		module: "MMM-MplayerRadio",
          		header: "Radio",
          		position: "top_center",
          			stations: [
          					title: "Almubarak",
          					url: "https://relay.emasjidlive.uk/almubarakradio",
          					logo: "https://almubarakradio.com/wp-content/uploads/2021/04/logorectangle-1024x326.png",
          					customCommand: "/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash",
          					customCommandArgs: ["10", "30", "###URL###"],
          I added this line aswell
          customCommandArgs: [“-I”,“dummy”, “–http-reconnect”, “–http-continuous”, “###URL###”],
          but didn’t work
          • T Offline
            tanvir586 @tanvir586
            @tanvir586 If I used this config then the sound works but open vlc in separate windows
            	header: "Radio",
            		stations: [
            				title: "Almubarak",
            customCommand: “/usr/bin/vlc”,
            customCommand: “/home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash”,
            customCommandArgs: [“10”, “30”, “###URL###”],
            • T Offline
              tanvir586
              If I use this config then vlc open is separate window and it’s looks like this.
              		header: "Radio",
              			stations: [
              					title: "Almubarak",
              					url: "https://relay.livemasjid.com:8443/activestream",
              					customCommand: "/usr/bin/vlc",
              picture ;-
                @tanvir586 Sorry, i am not at my pc at the moment. You only need the first customCommand line. The one with vlc is wrong.
                You can try to run the run the command directly on the shell and see what happens.
                /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash 10 30 https://relay.emasjidlive.uk/almubarakradio
                You can end it by pressing CRTL+c
                • T Offline
                  @wishmaster270 Hi, it’s says this
                  tanvir@raspberrypi:~ $ /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash 10 30 https://relay.emasjidlive.uk/almubarakradio
                  bash: /home/pi/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash: No such file or directory
                  • T Offline
                    @tanvir586 and I installed mplayer.
                      @tanvir586 Are you sure you are running the latest version of the module?
                      The error says that the wrapper script I added yesterday does not exist.
                      Can you please check the script folder and check if the file is executable?
                      • T Offline
                        @wishmaster270 I’ve updated yesterday. I’ll check again now
                        • T Offline
                          tanvir586
                          Should I reinstall? Or delete the module and fresh install?
                            @tanvir586 You installed to a different user. Your path will be
                            /home/tanvir/MagicMirror/modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash
                            T 2 Replies Last reply Reply Quote 0
                            • T Offline
                              @wishmaster270 ok I’ll check shortly.
                              • T Offline
                                @wishmaster270 Hi mate…
                                  @tanvir586
                                  It looks like you use the right version but only the path in the “customCommand” option was wrong. With the following config it should work:
                                  		header: "Radio",
                                  			stations: [
                                  					title: "Almubarak",
                                  					customCommand: "./modules/MMM-MplayerRadio/scripts/streamlinkWrapper.bash",
                                  • T Offline
                                    @wishmaster270 Hi… the sound works perfectly. thank you very much. now just waiting now for the radio go offline and come back online. will text you back.
                                    • T Offline
                                      @wishmaster270 Hi. The Radio just came back online but no luck. Is doesn’t come online itself.
                                        @tanvir586 Hi, bad to hear that.
                                        At the moment I do not have any other idea.
                                        • T Offline
                                          @wishmaster270 That’s fine mate. Really appreciated you helping. Thank you very much.
                                          • T Offline
                                            tanvir586
                                            Hi mate started using your module back again. now I’m using a station which is 24/7. all working very good. just one help I need now. just wanna to reduce the size of the control Wrapper. I edit the mplayer-radio.css file. I was able to reduce the top part but the bottom part is not reducing. I edit
                                            .mradio .controlWrapper {
                                            padding-top: 5px;
                                            width: 100%;
                                            and add hight: 100%;
                                            but it did not work. anything I can do on this?
                                            • 2 / 3
