    Calendar and Icons
    18 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @bicolorbore586
      @bicolorbore586
      https://fontawesome.com/search?q=swimming &o=r
      I don’t see a ‘swimming’ icon, I do see
      ‘person-swimming’
      is cx3 using a different icon lib is it’s css ?
        bicolorbore586 @sdetweil
        Not sure I understand the question. I know from the github page it talks about EX3 taking information from the default calendar.
        Have just tried person-swimming, but still gives same results.
          @bicolorbore586 can u open the developers window, ctrl-shift-i, and select the console tab, and put cal
          in the filter field
          to see if there is any error
            Styles loaded for: MMM-CalendarExt3
            loader.js:164 Translations loaded for: MMM-CalendarExt3Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
            2calendar.js:89 Starting module: calendar
            localhost/:1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
              @bicolorbore586 that means custom.css doesn’t exist(which means u didn’t use my install script, cause I create it) from a termianl window, do
              touch ~/MagicMirror/css/custom.css
                @sdetweil No longer get the error, but the icon’s still don’t show
                  @bicolorbore586 see this,
                  https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1666112801067
                  navigate to the calendar entry to see what the element looks like and if symbol is used…
                    for comparison, using a UK holiday calendar, the default icon is present, but the sleigh for Christmas isn’t
                      @bicolorbore586 interesting…
                      but they don’t contain the font awesome prefixes
                      				symbol.className = "fas fa-fw fa-" + s
                      what version of MagicMirror are u on?
                      see the startup messages or
                      grep version ~/MagicMirror/package.json
                      for grins change the symbol in custom event entry to
                      ‘fa-swimming’
                      it will probably fail in ext3
                        @sdetweil v 2.22.0-develop
                        changing to fa-swimming removes the icon from ext3 as you predicted. Still not showing in default calendar either.
