    Calendar and Icons
    18 Posts 3 Posters 6.0k Views 3 Watching
      bicolorbore586 @sdetweil
      Styles loaded for: MMM-CalendarExt3
      loader.js:164 Translations loaded for: MMM-CalendarExt3Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
      2calendar.js:89 Starting module: calendar
      localhost/:1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
        sdetweil @bicolorbore586
        @bicolorbore586 that means custom.css doesn’t exist(which means u didn’t use my install script, cause I create it) from a termianl window, do
        touch ~/MagicMirror/css/custom.css
          @sdetweil No longer get the error, but the icon’s still don’t show
            @bicolorbore586 see this,
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1666112801067
            navigate to the calendar entry to see what the element looks like and if symbol is used…
              for comparison, using a UK holiday calendar, the default icon is present, but the sleigh for Christmas isn’t
                @bicolorbore586 interesting…
                but they don’t contain the font awesome prefixes
                				symbol.className = "fas fa-fw fa-" + s
                what version of MagicMirror are u on?
                see the startup messages or
                grep version ~/MagicMirror/package.json
                for grins change the symbol in custom event entry to
                ‘fa-swimming’
                it will probably fail in ext3
                  @sdetweil v 2.22.0-develop
                  changing to fa-swimming removes the icon from ext3 as you predicted. Still not showing in default calendar either.
                    @bicolorbore586 but if u examine the content again it should say fa-swimming
                    I just switched to 22 develop and still see the same code
                      MMRIZE @bicolorbore586
                      @bicolorbore586
                      2.22.0-develop? not 2.21.0-develop?
                      B S 2 Replies Last reply Reply Quote 0
                        bicolorbore586 @MMRIZE
                        @MMRIZE Yes, although I have now downgraded to 2.21.0. Still experiencing the same issue.
                          @bicolorbore586
                          In my test on 2.21,
                          swimming, person-swimming, swimmer showed the right result. It is very interesting why yours is not.
                            @MMRIZE If I change / add fas fa-fw fa-symbol name, that appears to have resolved the issue.
                              sdetweil @MMRIZE
                              @MMRIZE 22-develop is the name of the upcoming release develop branch in package json
                              so main is 2.21.0
                              develop is 2.22-develop
                                @bicolorbore586 I checked 19, 20,21…
                                the extra classes are added under the covers… hard coded
