    Calendar and Icons
    18 Posts 3 Posters 6.0k Views 3 Watching
      bicolorbore586
      Hi again,
      below is a brief part of my config.js. A few days ago this was working fine, however now it no longer shows the icon/symbol in the default calendar.
      Note there is also configuration for colors which does work.
      			header: "FamCal",
      			config:	{
      				displaySymbol: true,
      				customEvents: [	{keyword: "Swimming", symbol: "swimmer"},
      it does however show the icon in the MMM-Calendarext3
        sdetweil @bicolorbore586
        @bicolorbore586
        https://fontawesome.com/search?q=swimming &o=r
        I don’t see a ‘swimming’ icon, I do see
        ‘person-swimming’
        is cx3 using a different icon lib is it’s css ?
          bicolorbore586 @sdetweil
          Not sure I understand the question. I know from the github page it talks about EX3 taking information from the default calendar.
          Have just tried person-swimming, but still gives same results.
            @bicolorbore586 can u open the developers window, ctrl-shift-i, and select the console tab, and put cal
            in the filter field
            to see if there is any error
              Styles loaded for: MMM-CalendarExt3
              loader.js:164 Translations loaded for: MMM-CalendarExt3Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
              2calendar.js:89 Starting module: calendar
              localhost/:1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
                @bicolorbore586 that means custom.css doesn’t exist(which means u didn’t use my install script, cause I create it) from a termianl window, do
                touch ~/MagicMirror/css/custom.css
                  @sdetweil No longer get the error, but the icon’s still don’t show
                    @bicolorbore586 see this,
                    https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1666112801067
                    navigate to the calendar entry to see what the element looks like and if symbol is used…
                      for comparison, using a UK holiday calendar, the default icon is present, but the sleigh for Christmas isn’t
                        @bicolorbore586 interesting…
                        but they don’t contain the font awesome prefixes
                        				symbol.className = "fas fa-fw fa-" + s
                        what version of MagicMirror are u on?
                        see the startup messages or
                        grep version ~/MagicMirror/package.json
                        for grins change the symbol in custom event entry to
                        ‘fa-swimming’
                        it will probably fail in ext3
                          @sdetweil v 2.22.0-develop
                          changing to fa-swimming removes the icon from ext3 as you predicted. Still not showing in default calendar either.
                            @bicolorbore586 but if u examine the content again it should say fa-swimming
                            I just switched to 22 develop and still see the same code
                              MMRIZE @bicolorbore586
                              @bicolorbore586
                              2.22.0-develop? not 2.21.0-develop?
                              B S 2 Replies Last reply Reply Quote 0
                                bicolorbore586 @MMRIZE
                                @MMRIZE Yes, although I have now downgraded to 2.21.0. Still experiencing the same issue.
                                  @bicolorbore586
                                  In my test on 2.21,
                                  swimming, person-swimming, swimmer showed the right result. It is very interesting why yours is not.
                                    @MMRIZE If I change / add fas fa-fw fa-symbol name, that appears to have resolved the issue.
                                      sdetweil @MMRIZE
                                      @MMRIZE 22-develop is the name of the upcoming release develop branch in package json
                                      so main is 2.21.0
                                      develop is 2.22-develop
                                        @bicolorbore586 I checked 19, 20,21…
                                        the extra classes are added under the covers… hard coded
