cronjob vcgencmd display_power
15 Posts 4 Posters 3.4k Views 4 Watching
    megagprime
    Hi guys, i am having trouble getting the magicmirror to turn the screen on and off with cronjob. I have used them before and it used to work and works with other installations with root /usr/bin…>/dev/null 2>&1 command but does not work anymore. I have tried all these variations and none work. I have used system wide cron with sudo nano edit and the reboot actually works…56cee79b-2240-43b0-91c0-78664a2d9871-image.png
      megagprime
      this is on pi3 and i also tried modifying boot/config.txt file
      Enable DRM VC4 V3D driver
      dtoverlay=vc4-kms-v3d (changed to fkms)
      max_framebuffers=2
      M 1 Reply Last reply Oct 27, 2022, 4:41 PM Reply Quote 1
      • M Online
        mumblebaj Module Developer @megagprime
        @megagprime This is how I run mine. I have 2 scripts and I call these scripts from the cron and not the actual vcgencmd
        And in the scripts I run the following:
        This works perfectly for me. Give it a go and let’s see if that works. I run an RPI 3B.
        M 1 Reply Last reply Oct 31, 2022, 3:12 PM Reply Quote 0
          megagprime @mumblebaj
          @mumblebaj ya even this didnt work, maybe i need to change my boot/config file back to kms
          M 1 Reply Last reply Nov 8, 2022, 6:33 PM Reply Quote 0
            megagprime @megagprime
            @megagprime anybody have any ideas why this doesnt work and should i change my boot file?
            N 1 Reply Last reply Nov 25, 2022, 4:42 PM Reply Quote 0
            • N Offline
              Nneuland @megagprime
              @megagprime
              Did you ever figure this out? I’m having the same issue
              M 1 Reply Last reply Jan 6, 2023, 11:41 PM Reply Quote 0
                megagprime @Nneuland
                @Nneuland nope, still no dice. building a new mm now, will update
                S 1 Reply Last reply Jan 6, 2023, 11:54 PM Reply Quote 0
                • S Away
                  sdetweil @megagprime
                  @megagprime @Nneuland depending on the board firmware, the vcgencmd may or may not work
                  this was reported and worked thru in the fall.
                  see https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi/20?_=1672509926391
                  M 1 Reply Last reply Jan 12, 2023, 2:43 PM Reply Quote 0
                    megagprime @sdetweil
                    @sdetweil hi there, i still dont see a fix or alternative workaround. The commands themselves work i just cant get it to work with cronjon :(
                    S 1 Reply Last reply Jan 12, 2023, 2:44 PM Reply Quote 0
                    • S Away
                      @megagprime what user is cron executing them as?
                      what user do you use when testing?
                      cron is root by default unless u add another parm for the username
                      M 2 Replies Last reply Jan 12, 2023, 3:03 PM Reply Quote 0
