    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      sdetweil @Wenike
      @Wenike your transformer is only doing style change,
      he wants to change the class , so his transformer is ok
        MMRIZE @chadjohn2
        @chadjohn2
        There were several issues on your code.
        1. You didn’t return event object in your eventTransformer function.
        2. CSS(Cascading Style Sheets) has a Speciality to determine the priority of the definitions by calculation.
          Your .CX3 .Daycare is lower than default .CX3 .event.fullday or .CX3 .event.multiday. So in case of your event is fullday/multiday thing, your color definition would be ignored.
          .CX3 .event.Daycare or .CX3 .event.Daycare.fullday, .CX3 .event.Daycare.multiday would work.
          DDE12
          How do I reference the specific instances of CExt3? Like on different carousel pages, where I would have a month mode on one page and a week mode on another. I have this config:
                      broadcastPastEvents: true,
                      maximumNumberOfDays: 300,
                          instanceId: "FamilyCal",
                          fade: false,
                          colored: true,
                          displaySymbol: false,
          		        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                  color: "rgb(240,175,20)"
                                  url: "https://private.calendar.com",
                                  color: "rgb(60,250,60)"
                                  color: "rgb(250,40,150)"
                                  color: "rgb(180,40,250)"
                    module: "MMM-CalendarExt3",
                    position: "fullscreen_above",
                    title: "",
                          mode: "month",
                          instanceId: "FamilyMonth",
                          calendarSet: ['Holidays', 'Dad', 'Mom', 'Child'],
                          maxEventLines: 5,
                          firstDayOfWeek: 0,
                          minimalDaysOfNewYear: 1,
                          eventHeight: '18px',
                          useSymbol: false
                      title: "",
                          mode: "week",
                          instanceId: "FamilyWeek",
                          weekIndex: -1,
                          weeksInView: 5,
                          maxEventLines: 5,
                          firstDayOfWeek: 0,
                          useSymbol: false
            sdetweil @DDE12
            @DDE12 for each module you can ADD classes strings , by using the classes:“…”
            property after the
            module:“… name”
            then in pages you can use that name instead of the module name
            I prefer to configure pages differently
            in pages its
                    [  'page1'],
                    [  'page2' ]
            then for the modules u want on page1
            you add
              classes:'page1',
            and for modules on page2
               classes:'page2'
            you can do the same for fixed, etc
              DDE12 @sdetweil
              Thank you for looking at this. Is this the proper implementation for your suggestion?
              modules:  [
                 ['MonthPage'],
                 ['WeeksPage']
                        classes: 'MonthPage',
                                   mode: "month",
                        classes: 'WeeksPage'
                                   mode: "week",
                        module: "MMM-Carousel",
                                      mode: 'slides',
                                      slides: {
                                                 "Slide 2": ['MonthPage'],
                                                 "Slide 3": ['WeeksPage']
                sdetweil @DDE12
                @DDE12 no, I was giving you the config for the MMM-Pages module.
                I don’t use Carousel, so not sure there
                  DDE12 @sdetweil
                  Like so…?
                  modules:  [
                                       mode: "month",
                                       mode: "week",
                              module: 'MMM-pages',
                                                              ['MonthPage'],
                                                              ['WeeksPage']
                    sdetweil @DDE12
                    @DDE12 yes
                    I would label the pages ( in pages config)
                    page1
                    page2
                    cause that is the order they are shown.
                    you can have as many modules on a page as u want and can fit of course.
                      DDE12 @sdetweil
                      Yeah, that would definitely be less confusing. Do I have the classes: “FamilyWeek” and classes: “FamilyMonth” in the right place in the CalenderExt3 config(s)?
                        sdetweil @DDE12
                        @DDE12 either can be used in css to select elements to style
                          DDE12 @sdetweil
                          I’m completely lost now. I thought all of this went in config.js.
                            sdetweil @DDE12
                            @DDE12 all of THAT goes.in config.js
                            but if you want to change the color of the text for the second day of the week
                            in custom.css
                            . MMM-CalendarExt3  .weekday_1 {
                                  color:green;
                            • B Online
                              bicolorbore586
                              @fedale @MMRIZE @chadjohn2 I am also trying (unsuccessfully) to have the Calendar event change color depending on which name is in the title.
                              With the original magicmirror calendar, I’ve used
                              customEvents: [ {keyword: “Ben”, color: “Brown”} ], which shows the event title and associated symbol in Brown.
                              In EXT3, using eventTransformer, only the symbol shows in color
                              I’ve tried to use
                              eventTransformer: function(event) {
                              if (event.title.search(“Ben”) > -1) {
                              event.className = “Ben”;
                              with customer.css
                              .CX3 .Ben {
                              color: brown;
                              However, this then shows a blank calendar
                              Have any of you been successful?
                              Where am I going wrong?
                                MMRIZE @bicolorbore586
                                @bicolorbore586
                                You have to return event object in eventTransformer function. When you omit ‘return’ statement in a function, implicitly it is same with ‘return null’
                                • B Online
                                  bicolorbore586 @MMRIZE
                                  @MMRIZE have tried that, still doesn’t show anything.
                                  return event
                                  • mumblebajM Offline
                                    mumblebaj Module Developer @bicolorbore586
                                    @bicolorbore586 If I am not mistaken, your return goes outside the IF statement
                                    BKeyportB B 2 Replies Last reply Reply Quote 0
                                    • BKeyportB Online
                                      BKeyport Module Developer @mumblebaj
                                      @mumblebaj
                                      Try this:
                                      eventTransformer: function(ev) {
                                        if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                                        return ev
                                      directly off the README.md :
                                      eventTransformer: (ev) => {
                                        if (ev.title.search('John') > -1) ev.color = 'blue'
                                        return ev
                                      • B Online
                                        bicolorbore586 @mumblebaj
                                        @mumblebaj so that now means I can see the events again, but still not coloured how I want.
                                          mike23pizzo
                                          I’m having some issues with broadcastPastEvents: true. Past events aren’t showing up on the calendar. Below is the default calendar code and the MMM-CalendarExt3 code. As well as a screenshot.
                                          			header: "Events",
                                          				fetchInterval: "1000",
                                          				colored: true,
                                          						url: //URL//,
                                          						symbol: "calendar-check",
                                          						color: "#338FFF",
                                          						url:  //URL//,
                                          						url:  //URL//,
                                          						symbol: "utensils",
                                          						color: "#FFFB21",
                                          			position: "bottom_right",
                                          			weekIndex: "0",
                                          				mode: "week",
                                          				firstDayOfWeek: "0",
                                          				refreshInterval: "10000",
                                          				calendarSet: ['us_holidays','mikes_cal','dinners'],
                                            sdetweil @mike23pizzo
                                            @mike23pizzo it’s only set before the calendars list.
                                            what mm version are u on? fix in latest 2.20 for events being truncated
                                            • 10
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
