    MMM-CalendarExt3
    689 Posts 82 Posters 2.8m Views 86 Watching
      almightyyoshi @MMRIZE
      @MMRIZE
      That did it. Thanks!
        chadjohn2
        First off, I’m a complete and utter noob with coding. I’m capable enough to get MagicMirror installed and start adding in some of the 3rd party modules. I’m now trying to get into the space of modifying CSS and such for a little added customization.
        I’m trying to something that I think should be simple but I cannot get it work for the life of me. I’ve searched the forum and this topic and found a couple pieces but I’m still struggling. Finally got frustrated enough to create an account and post.
        I’m trying to change the color of events based on the title of an event coming from a google calendar. The events are coming in fine, just not changing color.
        Based on what I have read, I need to use the eventTransformer function. I have put the following into the config.js file (including the full module for total information).
        module: "MMM-CalendarExt3",
        position: "bottom_bar",
        			mode: "week",
        			weekIndex: "0",
        			weeksInView: "2",
        			firstDayOfWeek: "1",
        			maxEventLines: "8",
        			fontSize: "25px",
        			eventHeight: "16px"
        eventTransformer: function(event) {
        if (event.title.search('Daycare') > -1) {
        event.className = 'Daycare'
        then in the custom.css file (Trying hot pink hex so it pops out):
        .CX3 .Daycare {
        background-color:#FF69B4;
        color:#FF69B4;
        For all I know, that’s completely wrong so any help you can provide will be appreciated!
        W M 2 Replies Last reply Reply Quote 0
        • W Offline
          Wenike @chadjohn2
          @chadjohn2 Try removing the }, before your event transformer text (it closes that config section but you need the event transformer in that config section). Also, per the github, your code for the event transformer needs to be something like:
          eventTransformer: (ev) => {
            if (ev.title.search('Daycare') > -1) ev.color = '#FF69B4'
            return ev
            sdetweil @Wenike
            @Wenike your transformer is only doing style change,
            he wants to change the class , so his transformer is ok
              MMRIZE @chadjohn2
              @chadjohn2
              There were several issues on your code.
              1. You didn’t return event object in your eventTransformer function.
              2. CSS(Cascading Style Sheets) has a Speciality to determine the priority of the definitions by calculation.
                Your .CX3 .Daycare is lower than default .CX3 .event.fullday or .CX3 .event.multiday. So in case of your event is fullday/multiday thing, your color definition would be ignored.
                .CX3 .event.Daycare or .CX3 .event.Daycare.fullday, .CX3 .event.Daycare.multiday would work.
                DDE12
                How do I reference the specific instances of CExt3? Like on different carousel pages, where I would have a month mode on one page and a week mode on another. I have this config:
                            broadcastPastEvents: true,
                            maximumNumberOfDays: 300,
                                instanceId: "FamilyCal",
                                fade: false,
                                colored: true,
                                displaySymbol: false,
                		        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                        color: "rgb(240,175,20)"
                                        url: "https://private.calendar.com",
                                        color: "rgb(60,250,60)"
                                        color: "rgb(250,40,150)"
                                        color: "rgb(180,40,250)"
                          position: "fullscreen_above",
                          title: "",
                                mode: "month",
                                instanceId: "FamilyMonth",
                                calendarSet: ['Holidays', 'Dad', 'Mom', 'Child'],
                                maxEventLines: 5,
                                firstDayOfWeek: 0,
                                minimalDaysOfNewYear: 1,
                                eventHeight: '18px',
                                useSymbol: false
                            title: "",
                                mode: "week",
                                instanceId: "FamilyWeek",
                                weekIndex: -1,
                                weeksInView: 5,
                                maxEventLines: 5,
                                firstDayOfWeek: 0,
                                useSymbol: false
                  sdetweil @DDE12
                  @DDE12 for each module you can ADD classes strings , by using the classes:“…”
                  property after the
                  module:“… name”
                  then in pages you can use that name instead of the module name
                  I prefer to configure pages differently
                  in pages its
                          [  'page1'],
                          [  'page2' ]
                  then for the modules u want on page1
                  you add
                    classes:'page1',
                  and for modules on page2
                     classes:'page2'
                  you can do the same for fixed, etc
                    DDE12 @sdetweil
                    Thank you for looking at this. Is this the proper implementation for your suggestion?
                    modules:  [
                       ['MonthPage'],
                       ['WeeksPage']
                              classes: 'MonthPage',
                                         mode: "month",
                              classes: 'WeeksPage'
                                         mode: "week",
                              module: "MMM-Carousel",
                                            mode: 'slides',
                                            slides: {
                                                       "Slide 2": ['MonthPage'],
                                                       "Slide 3": ['WeeksPage']
                      sdetweil @DDE12
                      @DDE12 no, I was giving you the config for the MMM-Pages module.
                      I don’t use Carousel, so not sure there
                        DDE12 @sdetweil
                        Like so…?
                        modules:  [
                                             mode: "month",
                                             mode: "week",
                                    module: 'MMM-pages',
        ['MonthPage'],
        ['WeeksPage']
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 68
                        • 69
                        • 18 / 69
