    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      sdetweil @fedale
      @fedale i only see the wn 42 in the header of the 1st day of the week cell, same as the examples in the doc
      • N Offline
        nearmiss
        New to MMM-CalendarExt3 so perhaps just missing the obvious… how do I get event locations to show up? In Ext2 there was a hidden div that could be shown via CSS if I recal, but I don’t see that with Ext3?
        Other question is, is it possible to wrap longer event title names? I see the default calendar module has options around this, but they don’t seem to impact what Ext3 is doing, which I suppose makes sense.
          MMRIZE @fedale
          @fedale
          For CX2, I thought it was not pretty to have the week number column separately, and it is a bit of waste to occupy the expensive real estate of the MM screen, so in CX3, I put the week number into the cell as small as possible.
          Conclusively, a separated week number column is not possible in CX3 atm, And I think it would be undesirable, so I’ll not consider it.
          • F Offline
            fedale
            Ok thanks for the feedback.
            I have another question
            The new calendarExt3 and the i cant seem to get this transform fuction to work anymore. I had the transform in the config.js file and the custom.css with different words to get different color on each work, as we have family calendar.
            Tried to change it to cx3 without any luck. (/* */ is only to stop the code here.)
            Example
            transform: function(event) {
            if (event.title.search(“Jobb”) > -1) {
            event.icon = “ic:outline-work-outline”;
            event.className = “Jobb”;
            In the custom.css:
            .CX3 .Jobb.fullday {
            background-color:rgba(0,128,128);
            color:#000;
            .CX3 .Jobb {
            color:#000;
              MMRIZE @fedale
              @fedale
              ‘eventTransformer’
                MMRIZE
                Updated 1.2.5 (2022-11-04)
                • Added Display legend of the calendar (displayLegend: true and when you set the calendar name on the calendar module)
                • Fixed Some CSS fixture
                • L Offline
                  Lilleberg @MMRIZE
                  @MMRIZE I’m trying to update the module but it seems like the update doesn’t work. Maybe I’m doing it wrong? I have copied in the commands I’m using in the terminal. According to that it looks like the update is working fine. But when I start the MagicMirror there is still a notification at the top that the CalendarExt3 module is “2 commits behind the main grenen”.
                  Also I can’t display the legend when I insert this under the config in the CalendarExt3 module.
                  lilleberg@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-CalendarExt3
                  lilleberg@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
                  Updating 04883bc..ecd6b7a
                  error: Your local changes to the following files would be overwritten by merge:
                  	MMM-CalendarExt3.css
                  	MMM-CalendarExt3.js
                  Please commit your changes or stash them before you merge.
                  Aborting
                  lilleberg@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt3 $ npm install
                  up to date, audited 1 package in 598ms
                  found 0 vulnerabilities
                  • L Offline
                    Lilleberg @MMRIZE
                    @MMRIZE My language and locale are Norwegian. Using nb in the config file.
                    • L Offline
                      Lilleberg @MMRIZE
                      @MMRIZE Thanks!
                      1 Reply Last reply Reply Quote -1
                        sdetweil @Lilleberg
                        @Lilleberg said in MMM-CalendarExt3:
                        MMM-CalendarExt3.js
                        looks like u modified the module code, and updated cannot be applied til you fix that.
                        generally you never edit the source files of a module.all config goes in config.js and all css updates go is custom.css
                          bicolorbore586 @MMRIZE
                          Is there an option to hide the week numbers? I’ve managed to remove the ‘cw’ using custom.css (albeit a bit untidy)
                            sdetweil @bicolorbore586
                            @bicolorbore586 no config option, just set cw to display:none in custom.css
                              almightyyoshi
                              I finally found a touch module that I could easily use for the glance notification and have the payload step as 1. However, two things are happening:
                              1: on the first press it’s going back to June. Second press goes to April. Third press goes to August. Fourth press goes to December (which would be correct, however, due to the other jumps it could just be random)
                              2: no events are populating in the glance
                              Here’s what I have for the button:
                                    module: "MMM-TouchButton",
                                        buttons: [
                                              icon: "fa fa-calendar-days",
                                              notification: "CX3_GLANCE_CALENDAR",
                                              payload: {instanceID: [], step: [1]},
                              And here’s my CX3 config:
                                          module: "MMM-CalendarExt3",
                                          position: "middle_center",
                                                  mode: "month",
                                                  instanceID: "currentMonth",
                                                  firstDayOfWeek: 0,
                                                  useSymbol: true,
                                                  glanceTime: 60000,
                                                  calendarSet: [],
                              Any thoughts?
                                MMRIZE @almightyyoshi
                                @almightyyoshi
                                Not real tested, but I think your config should be like this;
                                payload: {step: 1},
                                And about no event populating, It would be related to your maximumEntries , maximumNumberOfDays and boradcastPastEvents options of default calendar module.
                                  almightyyoshi @MMRIZE
                                  @MMRIZE
                                  That did it. Thanks!
                                    chadjohn2
                                    First off, I’m a complete and utter noob with coding. I’m capable enough to get MagicMirror installed and start adding in some of the 3rd party modules. I’m now trying to get into the space of modifying CSS and such for a little added customization.
                                    I’m trying to something that I think should be simple but I cannot get it work for the life of me. I’ve searched the forum and this topic and found a couple pieces but I’m still struggling. Finally got frustrated enough to create an account and post.
                                    I’m trying to change the color of events based on the title of an event coming from a google calendar. The events are coming in fine, just not changing color.
                                    Based on what I have read, I need to use the eventTransformer function. I have put the following into the config.js file (including the full module for total information).
                                    position: "bottom_bar",
                                    			mode: "week",
                                    			weekIndex: "0",
                                    			weeksInView: "2",
                                    			firstDayOfWeek: "1",
                                    			maxEventLines: "8",
                                    			fontSize: "25px",
                                    			eventHeight: "16px"
                                    eventTransformer: function(event) {
                                    if (event.title.search('Daycare') > -1) {
                                    event.className = 'Daycare'
                                    then in the custom.css file (Trying hot pink hex so it pops out):
                                    .CX3 .Daycare {
                                    background-color:#FF69B4;
                                    color:#FF69B4;
                                    For all I know, that’s completely wrong so any help you can provide will be appreciated!
                                    W M 2 Replies Last reply Reply Quote 0
                                    • W Offline
                                      Wenike @chadjohn2
                                      @chadjohn2 Try removing the }, before your event transformer text (it closes that config section but you need the event transformer in that config section). Also, per the github, your code for the event transformer needs to be something like:
                                      eventTransformer: (ev) => {
                                        if (ev.title.search('Daycare') > -1) ev.color = '#FF69B4'
                                        return ev
                                        sdetweil @Wenike
                                        @Wenike your transformer is only doing style change,
                                        he wants to change the class , so his transformer is ok
                                          MMRIZE @chadjohn2
                                          @chadjohn2
                                          There were several issues on your code.
                                          1. You didn’t return event object in your eventTransformer function.
                                          2. CSS(Cascading Style Sheets) has a Speciality to determine the priority of the definitions by calculation.
                                            Your .CX3 .Daycare is lower than default .CX3 .event.fullday or .CX3 .event.multiday. So in case of your event is fullday/multiday thing, your color definition would be ignored.
                                            .CX3 .event.Daycare or .CX3 .event.Daycare.fullday, .CX3 .event.Daycare.multiday would work.
                                            DDE12
                                            How do I reference the specific instances of CExt3? Like on different carousel pages, where I would have a month mode on one page and a week mode on another. I have this config:
                                                        broadcastPastEvents: true,
                                                        maximumNumberOfDays: 300,
                                                            instanceId: "FamilyCal",
                                                            fade: false,
                                                            colored: true,
                                                            displaySymbol: false,
                                            		        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        color: "rgb(240,175,20)"
        url: "https://private.calendar.com",
        color: "rgb(60,250,60)"
        color: "rgb(250,40,150)"
        color: "rgb(180,40,250)"
                                                      position: "fullscreen_above",
                                                      title: "",
                                                            mode: "month",
                                                            instanceId: "FamilyMonth",
                                                            calendarSet: ['Holidays', 'Dad', 'Mom', 'Child'],
                                                            maxEventLines: 5,
                                                            firstDayOfWeek: 0,
                                                            minimalDaysOfNewYear: 1,
                                                            eventHeight: '18px',
                                                            useSymbol: false
                                                        title: "",
                                                            mode: "week",
                                                            instanceId: "FamilyWeek",
                                                            weekIndex: -1,
                                                            weeksInView: 5,
                                                            maxEventLines: 5,
                                                            firstDayOfWeek: 0,
                                                            useSymbol: false
                                            • 10
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
